ECU resetting after BROLA install yes or no?
Old Jun 18, 2003 | 06:17 AM
DMONTE's Avatar
DMONTE
Default ECU resetting after BROLA install yes or no?
I am trying to decide if I should reset my ECU after installation of the exhaust by disconnecting the battery?
Does anyone know if there is any downside to doing this?
Thanks
DMonte
Old Jun 18, 2003 | 07:11 AM
350zSpeedRacer's Avatar
350zSpeedRacer
You'll just have to reset your clock and radio stations.
Old Jun 18, 2003 | 07:58 AM
D_Nyholm's Avatar
D_Nyholm
I don't think that there is any reason to disconnect the battery if you do exhaust mods since nothing is measured by the ECU in the exhaust. If you did INtake mods, I would think it would be a good idea to disconnect it.
Old Jun 18, 2003 | 02:15 PM
peptidbond's Avatar
peptidbond
Umm, are not the O2 sensors in the exhaust system? Not sure what kind of information the ECU would be able to glean from the sensors, but I suspect that an abundance of O2 would mean that a mod has been installed. Just a conjecture.
Old Jun 18, 2003 | 03:45 PM
MannishBoy's Avatar
MannishBoy
It takes 24 hours according to the shop manual to reset the ECU if you just pull the battery.
You can also do it this way:
1) Make sure the ignition is switched off.
2) Wait at least 10 secs, then switch On (not started)
3) Wait 3 seconds
4) Press and release accelerator quickly 5 times within 5 seconds
5) Wait 7 seconds
6) Fully push and hold accelerator for 10 seconds until the MIL starts to blink
7) Release accelerator (you are in diagnostic mode)
8) To erase, press the accelerator fully and hold for at least 10 seconds
Old Jun 18, 2003 | 05:04 PM
DMONTE's Avatar
DMONTE
3) Wait 3 seconds
5) Wait 7 seconds
So do you think it would be a beneficial thing to do?
I guess I'm just not really sure what the ECU exactly does, by resetting it will that just speed up the process of equaling out the power again it seems like a lot of people are losing their gained performance after a while because of the ECU.
Old Jun 18, 2003 | 05:45 PM
MannishBoy's Avatar
MannishBoy
It will just relearn things over time. It won't hurt, but it would probably only speed the changes up a bit at best.
*shrug*
Old Jun 18, 2003 | 07:00 PM
shaneotool's Avatar
shaneotool
hell, why don't you just do this every morning when you get in the car, then you don't have to worry about the ECU learning your mods and erasing the gains.
I'd like to see someone thats had an exhaust and intake for a while go get a dyno done, then do this pedal thing to clear the ECU then dyno again to see the difference.
Old Jun 18, 2003 | 08:02 PM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
So would I! If this sequence truely resets the ECU then theoretically one should see an increase in HP with a mod, then a loss of HP back to baseline then a regaining of HP after this resetting.
This would be a great experiment for someone who has the services of a Dyno!
Anyone?......Anyone?.....
Old Jun 19, 2003 | 09:32 AM
D_Nyholm's Avatar
D_Nyholm
umm, aren't the O2 sensors BEFORE the exhaust? That would mean that the exhaust would have nothing to do with the O2 sensors and their readings. The only thing they may read differently is the amount of flow, but O2 sensors do not read that, only the ratio of air to exhaust/unburnt fuel.
Old Jun 19, 2003 | 11:33 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
just maybe the flow is better with the Borla exhaust so the intake is actually has more velocity?
Old Jun 19, 2003 | 03:57 PM
MannishBoy's Avatar
MannishBoy
O2 are after the engine, the first ones are in the exhaust manifold, the second ones are after the cats.
Old Jun 19, 2003 | 04:58 PM
MustGoFastR's Avatar
MustGoFastR
3) Wait 3 seconds
5) Wait 7 seconds
Can you say exactly where in the manual it describes this? The only thing I can find is the following procedure for idle air volume learning, which looks remarkably like the procedure you listed, but doesn't say anything about the ECM resetting:
Idle Air Volume Learning Description:
“Idle Air Volume Learning” is an operation to learn the idle air volume that keeps each engine within the specific
range. It must be performed under any of the following conditions:
_ Each time electric throttle control actuator or ECM is replaced.
_ Idle speed or ignition timing is out of specification.
Without CONSULT-II
NOTE:
_ It is better to count the time accurately with a clock.
_ It is impossible to switch the diagnostic mode when an accelerator pedal position sensor circuit
has a malfunction.
1. Perform EC-50, "Accelerator Pedal Released Position Learning" .
2. Perform EC-51, "Throttle Valve Closed Position Learning" .
3. Start engine and warm it up to normal operating temperature.
4. Check that all items listed under the topic “PREPARATION” (previously mentioned) are in good order.
5. Turn ignition switch “OFF” and wait at least 10 seconds.
6. Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
7. Repeat the following procedure quickly five times within 5 seconds.
a. Fully depress the accelerator pedal.
b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the MIL stops
blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the MIL goes off.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure that idle speed and ignition timing are within the
specifications.
13. If idle speed and ignition timing are not within the specification, “Idle Air Volume Learning” will not be carried
out successfully. In this case, find the cause of the incident by referring to the “DIAGNOSTIC PROCEDURE”
hulkout
Tuning
Sep 30, 2015 12:33 PM
