Rev-up Engine
Old Feb 10, 2008 | 06:57 PM
skodra's Avatar
skodra
Default Rev-up Engine
I have just purchased a 2005 350z touring. How do I know if this is the Rev-up engine or not? Thx
Old Feb 10, 2008 | 07:04 PM
moflow's Avatar
moflow
redline at 7k? if yes then it's a rev-up. But it's probably not because only the 35th anniversery and the track model were rev-ups in 2005
Old Feb 10, 2008 | 07:21 PM
NISMO_558's Avatar
NISMO_558
only the track, and anniversary edition came with the rev-up in '05
Old Feb 10, 2008 | 07:26 PM
sluggoZ's Avatar
sluggoZ
Yes....but stick only not the 5SAT.
skodra's Avatar
skodra
Default Thx
I saw a thread on this. Wanted to know before I order the Plenum spacer.
Old Feb 10, 2008 | 07:34 PM
NISMO_558's Avatar
NISMO_558
good call, my bad
Old Feb 10, 2008 | 08:54 PM
ladyzed's Avatar
ladyzed
Tracks in 05 had the revup ?
Old Feb 11, 2008 | 03:42 AM
Reality350's Avatar
Reality350
^yes
Old Feb 12, 2008 | 06:43 PM
ekelly36's Avatar
ekelly36
ok so if on my tach the redline is 7k I have the rev up? because on mine it shows the redline right at 7k but I have a base model.. hell I dont even have cruise control..... im confused....
Old Feb 12, 2008 | 06:48 PM
surfcity40's Avatar
surfcity40
Here:
http://www.seriouswheels.com/cars/to...ary-Z-350Z.htm
The same engine will also be available as standard equipment on the 2005 350Z Track model (6MT only), which also goes on sale in early 2005.
Old Feb 12, 2008 | 11:14 PM
T_K's Avatar
T_K
06
TK
Old Feb 13, 2008 | 01:57 AM
zyou8er's Avatar
zyou8er
Why would you want a revup anyways, they have a oil consumption issues.
Old Feb 13, 2008 | 05:23 AM
gothchick's Avatar
gothchick
Mine doesn't. But I guess I can fix it so it does~ Lol.
Old Feb 13, 2008 | 10:28 AM
ke0ki2k's Avatar
ke0ki2k
right at 7k? or right at 6600?...
Old Feb 13, 2008 | 11:55 AM
RBlover69's Avatar
RBlover69
mine doesnt anymore either fixed with v-2 and 0w40 mobile 1 oil
Old Feb 13, 2008 | 06:28 PM
undrgnd's Avatar
undrgnd
Mine doesn't, and even if it did, I would re-ring and go. There is more to a revup than oil consumption. Do a little reading before you post any more brain farts like that.
Old Feb 14, 2008 | 06:04 AM
gothchick's Avatar
gothchick
+1
And if you're going to dismantle the motor to re-ring it, might as well bore .20 over, with new pistons, rods, balance & blueprint.
Old Feb 14, 2008 | 06:07 AM
Doba's Avatar
Doba
If thats a sure solution to the oil consumption problem why the hell aren't the dealerships doing this instead of the V2 which still isnt a 100% fix.
Old Feb 14, 2008 | 08:48 AM
KRRZ350's Avatar
KRRZ350
Because dealers don't touch imternals anymore, they even try to stear clear of short-blocks.
Also, it hasn't exactly been confirmed that the V2's aren't a fix, and who is to say what v2's did and didn't get different rings? until someone opens one up or someone can get there hands on a fast catalog for the m?z? part# engine than it's all speculation.
Old Feb 14, 2008 | 08:54 AM
KRRZ350's Avatar
KRRZ350
Forgot to add though, I wasn't saying the rings aren't the cause, because they are.
