unexpected noise
Old Feb 16, 2008 | 07:30 PM
blanning's Avatar
blanning
Default unexpected noise
My Z is a 2008 with 1400 miles on it. When I put the transmission in neutral and let out the clutch, with the windows down, I can hear an extra sound. I know it's the engine driving the input shaft of the transmission not connected to anything. When I put the clutch back in, I can hear the input shaft slowing to a stop in a few seconds. It doesn't really sound bad. And I can't hear it with the windows up. I just don't recall ever being about to hear this on any other car. The car drives great. Oh, and there's a bit on a rpm drop when I let the clutch out in neutral. The engine recovers from the extra load in less than a second and maintains the idle rpm. That's also unexpected. Is this a bearing on the input shaft going bad?
brian
Old Feb 16, 2008 | 07:34 PM
cheshirecat79's Avatar
cheshirecat79
What you are describing sounds normal. If you're really concerned, go to a dealership and crank up another manual Z. Push the clutch in and out and see if it makes the same noise.
Take a look in the Maintenance section. There's many threads in there about various noises from the clutch/tranny/flywheel that may help you.
Old Feb 16, 2008 | 07:53 PM
kramykram's Avatar
kramykram
It's not the bearing going bad it's just the bearing spinning on the pressure plate. Nothing but normal.
Old Feb 16, 2008 | 09:00 PM
350ZTheStandard's Avatar
350ZTheStandard
Nothing to worry about, this is just one of the known nuances of the Z car. RelaX
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
