Dyno 06 Revup with Bolt on's.
Just had my car dynoed at Mavrik Motorsports on 02/17/2008. Its a Mainline Dyno. Reads 20% lower than DJ.
239.7HP and 218.4ftlbs
Just want some of the experts to chime in on my run. Maybe tell me if the graph look ok and if my AFR is where it should be.
Mods:
HKS TD Exhaust, Helix TP's, MD 5/16" Iso Spacer, UR Pulleys, Pop Charger, JWT Flywheel, Nismo Clutch.
Will dyno again once I put my MREV2 back in.
Mods:
For comparison, here is my run from a year ago when all I had was Nismo Exhaust, 5/16 Iso spacer, MREV2 and PopCharger - 277hp and 263ftlbs tq
This of course on a Dynapack at Motordyne.
Originally Posted by 06MagneticZ
Can anyone comment on the dip at around 6k rpm's on the first graph? What would cause that to happen?
Originally Posted by gothchick
Would need to see a log with AFRs, timing, knock, inj duty, iat's, coolent temps, tps, load, etc to answer that...
