Redline 75W90 or 75W90 NS
Old Mar 5, 2008 | 02:25 PM
krnzzang84's Avatar
krnzzang84
Default Redline 75W90 or 75W90 NS
Hi guys i did search and didn't seem to find a answer!
I am going to do a Transmission and LSD Fluid change.
Going with Redline MT-90 and MTL. I am gonna mix 50/50 with MTL (70W80) and MT-90 (75w90) to achieve 75W85 for transmission and just using MT-90 for LSD!!! Here is the question: do i need a regular fluid or No-slip fluid??
LSD: slip or non-slip
Trans: slip or non-slip
how about the lsd modifier, do i need that???
Thanks
Old Mar 5, 2008 | 05:46 PM
undrgnd's Avatar
undrgnd
I used the exact same fluids and ratio. I never heard of the NS suffix, and I have the OEM LSD. Three years, no problems.
Old Mar 5, 2008 | 07:58 PM
dmroberson's Avatar
dmroberson
I have a base Z, and I was gonna use the 75w90NS in the rear differential, because I don't have VLSD, and decided that I don't need the friction modifier. I called Redline and asked about it.
They said, even though I don't have VLSD, I should use the 75w90 instead of the NS. The friction modifier in the 75w90 will help reduce differential temps more than the NS will.
Old Mar 5, 2008 | 08:01 PM
Motormouth's Avatar
Motormouth
redline diff fluid sucks.
Old Mar 6, 2008 | 04:11 AM
undrgnd's Avatar
undrgnd
Thanks for the useful feedback. Next time I change the fluid I will use something else.
Old Mar 6, 2008 | 08:04 AM
krnzzang84's Avatar
krnzzang84
hmm really i used it on my previous car and seem to be really good. But i might be wrong,, then what do you recommend mothermouth? motul??
thx for the replies guys! i really want to do this for spring!
Old Mar 6, 2008 | 05:50 PM
undrgnd's Avatar
undrgnd
Do your own research man. If you take any one person's opinion, especially one so contrary to what a logical person would accept, you are not a man, you're a sheep. There are several web sites that compare synthetic fluids, not all completely subjectively, but close enough. The bottom line is what one should expect from synthetics, most are very similar, and none 'suck'.
Old Mar 8, 2008 | 03:48 AM
Chiefryback's Avatar
Chiefryback
The NS modifier is intended for differentials with a clutch-type LSD. The viscous LSD which is fitted on the 350z from the factory doesn't benefit from it since the viscous housing is enclosed.
In theory you could use both with good results (which Redline confirmed). I have used the 75w90NS with good results as well. But the oil seems to wear out pretty quickly.
Old Mar 8, 2008 | 03:09 PM
krnzzang84's Avatar
krnzzang84
Decided to go with redline!
Transmission: 50/50 with MTL (70W80)/MT-90 (75W90) to creat 75w85, which is recommended by nissan!
LSD: 75W90
Even though 75w90 and MT-90 is same weight, the 75w90 contains additives for lsd, so anybody who are going with Redline, this is what you will be needing!!! MTL & MT-90 for transmission and plain 75W90 for LSD.
I was thinking of Motul but i have used redlines trans oil before and i was really satisfied.
Old Mar 10, 2008 | 11:45 PM
ZTMYDUST's Avatar
ZTMYDUST
I also went with that redline combo for my trans but forgot to order diff fluid, how much will i need? the nissan service manual says 2-3pts , 350ztech wiki says 2qts
Old Mar 11, 2008 | 07:14 AM
dmroberson's Avatar
dmroberson
I ordered 2 qts.
Old Mar 16, 2008 | 01:32 PM
djscotty's Avatar
djscotty
i just changed mine and it took 1-1/2 qts.
Old Apr 14, 2008 | 08:00 PM
ladyzed's Avatar
ladyzed
2 qts completely dry.
Old Apr 16, 2008 | 09:48 PM
anotheraznguy's Avatar
anotheraznguy
i am sorry but i used redline as well for the tranny
i will tell you this..
my tranny is super notchy and is impossible to get into gear anymore..
i am switching back to motul sooon
also it took me 3 qts...
Old Apr 20, 2008 | 04:28 PM
Asterix's Avatar
Asterix
Which oil? MTL? MT-90? 75W90? etc... Redline makes quite a few different formulations for different uses.
Me, I put half and half MTL and MT90 in my transmission and it shifts more smoothly than it ever did with Nissan's oil.
Asterix
Old Apr 20, 2008 | 09:06 PM
anotheraznguy
75w90 was what i used.
and ive also tried heavy duty shockproof back in the day...
neither of which did my tranny any good..
Old Apr 21, 2008 | 05:57 AM
Lawn Dart's Avatar
Lawn Dart
Do not use GL-5 oil in your transmission.
apex locator
Jul 23, 2021 02:27 AM
burglapfd
Dec 6, 2020 01:04 PM
Row2K
North East Marketplace
Dec 27, 2015 12:09 PM
Ace2347
Sep 22, 2015 03:12 AM
