whats the highest octane???
Old Mar 14, 2008 | 07:24 PM
ronie's Avatar
ronie
Default whats the highest octane???
can i run 116 octane on my 07z bonestock, some say yes some say no...obviously not for street use only at the track if not then what can i run?
Old Mar 14, 2008 | 07:28 PM
shift-er's Avatar
shift-er
as long as the gas is unleaded you can run pretty much whatever you want...although you may not have desired results.
However from my experience octane ratings this high normally contain lead content. Around here (Chi-town region) i can get 110 but it is leaded and would kill my 02 sensors after 50 or so miles.
You will gain no advantage by running 100, 110, C16, etc, unless you have a drag monster that is properly set up for it
Old Mar 14, 2008 | 07:32 PM
Nic@CiNcity's Avatar
Nic@CiNcity
Why would you waste the money buying it when you're bone stock car won't even know what to do with it?? You can paypal me $50 and get the same results. I'll send you a certificate that says your car is now faster to make you feel good.
Old Mar 14, 2008 | 07:35 PM
ronie's Avatar
ronie
nobody is pumping anything...its a curiosity question...loosen the panties you sound frustraded...
Old Mar 14, 2008 | 08:08 PM
FAIRLADYZ_MANnE's Avatar
FAIRLADYZ_MANnE
i guess if you tuned for it, you would benifit
Old Mar 14, 2008 | 10:56 PM
eltness350's Avatar
eltness350
The Untouchable
u can if its unleaded like stated...but that high of octane is usually leaded which means it will eat your cats up for din-din.....110 is the way to go...anything higher is kinda pointless unless its just a track beast....
Old Mar 15, 2008 | 10:30 PM
diesel350z's Avatar
diesel350z
http://forums.nasioc.com/forums/show...&highlight=e85
its a good read .
Old Mar 15, 2008 | 10:40 PM
cdoxp800's Avatar
cdoxp800
Old Mar 16, 2008 | 04:44 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
you know that higher octane fuel actually burns SLOWER right? Uber high octane gas won't help on a bone stock car no matter what anyone tells you.
I'd recommend mixing a little 100oct unleaded into your regular 91/93 octane gas if you are having pinging problems on a dyno or at the track
Old Mar 16, 2008 | 08:49 AM
doug's Avatar
doug
its going to make your car slower than stock.. so by all means go for it
Old Mar 16, 2008 | 09:14 AM
DJ SMITTY's Avatar
DJ SMITTY
CIN Motorsports
$14.00 a gallon for slower than stock...I certainly wouldn't do it.
Old Mar 16, 2008 | 01:54 PM
JETPILOT's Avatar
JETPILOT
Won't make your car any faster!
JET
Old Mar 16, 2008 | 02:50 PM
superchargedg's Avatar
superchargedg
Damn Noobs
JET
But if he uses the proper v-tech stickers in the right place it would.
Old Mar 16, 2008 | 04:45 PM
diesel350z's Avatar
diesel350z
Question about 2 gallons of E85 mixed in with 91 ?
also what about Toluene as a booster,
this is for a Turbo'ed set up.
Old Mar 16, 2008 | 06:25 PM
The Captain's Avatar
The Captain
It's all about V-TAK now.
http://www.youtube.com/watch?v=1yCQfQ69WdI
Old Mar 16, 2008 | 08:55 PM
terrasmak's Avatar
Actually it will be slower.
350z-to-be
West Canada
Aug 22, 2003 11:49 AM
MySunset350Z
Apr 21, 2003 07:00 AM
k2we
Apr 8, 2003 08:24 PM
chahny
Apr 1, 2003 07:50 AM
droideka
Aug 16, 2002 12:07 AM
