oil leak valve cover help!
ok i recently noticed a small oil leak on the driver side of my car and a bad burned smell after driving. i thought it was the return line from my supercharger but after checking several times i decided it is coming from somewhere else. i lifted the car and noticed oil all over the bottom of my alternater so i think it is coming from somewhere above that.. today i pulled my spark plugs and one of the driver side plugs is saturated with oil. so now i am thinking it must be the valve cover gasket now i have read different things some say that i can just replace the gaskets and it will be fine but i have also heard that i would need to replace the entire valve cover because of the oil in the sparkplugs. now im just wondering if everyone thinks that i am correct by thinking valve cover gasket and if i am on the right track to fix it.. any input is appriciated..
is it a new one or used? should i go ahead and replace both or just the one driver side? the passenger side ones werent covered in oil but there was a small trace on the threads is this normal?
Originally Posted by JETPILOT
They are used, but in good condition. Only 5000mi.
JET
JET
