Resetting the ECU data.
Old Jun 28, 2003 | 04:14 AM
uklooney's Avatar
uklooney
Lightbulb Resetting the ECU data.
Found this, if it is of any use to anyone....
Old Jun 28, 2003 | 06:04 AM
barrybell's Avatar
barrybell
Was this a publication? If so where?
Old Jun 28, 2003 | 07:01 AM
MannishBoy's Avatar
MannishBoy
It is out of the shop manual. The procedures for resetting codes, thottle, etc have been posted before recently, I think in TXSTYLE's Borla thread.
Old Jun 28, 2003 | 07:19 AM
pearl350z's Avatar
pearl350z
sorry for what might be a stupid question, but could someone please clarify what the chart is saying to do and the reasons for resetting the ecu. i have a few mods to the car and am wondering if this reseting will counter the downgrade of power due to the ecu correcting for the mods i have done.(exaust,intake,earthing kit,)thanks
Old Jun 28, 2003 | 11:58 AM
jckolnturn's Avatar
jckolnturn
does that mean if i do the river dance on my gas pedal it will reset my ECU?
Old Jun 28, 2003 | 12:05 PM
Judge's Avatar
Judge
Well... there seems to be two camps here. Some would say no.
If you believe what Technosquare is all about then yes.. it will 'un-detune' the ECU.
Spoken like a politically correct Clint E. Do you feel lucky.....Sir?
Old Jun 28, 2003 | 12:21 PM
chazzg's Avatar
chazzg
the easy to read Verson posted by Mannishboy a LOOOONG time ago... But i used it this moring and it works great.. (also a good trick for Racing)
1) Turn ignition on, wait 3 seconds
2) Push fully and release the gas pedal 5 times within 5 seconds
3) Wait 7 secs, fully push gas pedal and hold for 10 seconds until the CES light starts to blink
4) Release gas pedal (you are in diagnostic test mode 2)
5) Press and hold gas pedal for more than 10 seconds. Release pedal.
6) Sacrifice a goat, and pour its blood all over your naked body while trying to ask the spirit of Mahatma Gandhi to peacefully cut off the light without violence (perform this last step with the garage door close, as to avoid arrest)
Old Jun 28, 2003 | 12:58 PM
MannishBoy's Avatar
MannishBoy
That one at least resets the codes. There is also another very similar procedure that might be needed, too, that is in the Borla thread. I'm not sure if clearing the codes from diagnostics also clears the learning or not. I suspected it did initially, but after reading that other procedure, I'd probably do both just to be safe.
Old Jun 28, 2003 | 01:49 PM
chazzg's Avatar
chazzg
I cant find it. Can you please post it????
Old Jun 28, 2003 | 03:16 PM
MannishBoy's Avatar
MannishBoy
Oops, wrong thread. It is here.
Old Jun 28, 2003 | 04:00 PM
geezer902's Avatar
geezer902
I have to ask: if (as the posts the link ties to explain) resetting the ECU brings it back to its basic settings and then it will again learn to compensate for the mods .... why do it?
I'm not trying to argue but I'm not understanding why I'd do this -- lots of extra fuss for a very temporary adjustment.
Thankx in advance. J
Old Jun 28, 2003 | 04:40 PM
FLY BY Z's Avatar
FLY BY Z
If you go to the track it would be good so that you can have full advantage of your mods. Yes it is temporary until an ECU is released for the car.
Old Jun 28, 2003 | 05:58 PM
sschmuve's Avatar
sschmuve
Do u think this will reset my 2 degree timing advance?
Old Jun 28, 2003 | 06:15 PM
FLY BY Z's Avatar
FLY BY Z
Prolly. Unless it has already reverted back to normal. Then you don't have to worry. Even if the techs who did it say it won't revert, they don't know.
Old Jul 2, 2003 | 05:18 PM
mcclaskz's Avatar
mcclaskz
For those that have done this,
I can't seem to get my SES(CE) light to stop blinking after I make it blink. It seems to blink at varying rates, stops for a few seconds, and then blinks again. Am I doing this correctly? Did I reset it?
Old Jul 2, 2003 | 05:32 PM
chazzg's Avatar
chazzg
if you count the blinks (3 blinks pause 10 blinks pause 5 blinks) that is code 305. after it does that, hold down the Gas pedal for 10 more sec. and then it will only blink 10 times and repeat 10 blinks. That means you have reset the ECM
Old Jul 2, 2003 | 06:44 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
What about engine damage from revving the engine to redline for 10 seconds?
Old Jul 2, 2003 | 06:45 PM
chazzg's Avatar
chazzg
All of this HAS TO BE DONE WITH THE ENGINE OFF. But the Key "on"
Old Jul 2, 2003 | 08:34 PM
Buub's Avatar
Buub
My question:
Will resetting the ECU make the first-1200-mile break-in period start all over again? (My car has almost 12,000 miles on it and I'd not want to go through that again.)
Old Jul 3, 2003 | 01:33 AM
chazzg's Avatar
chazzg
Originally posted by Buub
My question:
Break in Has to Do with Letting all the seals, gaskets, and Pistons set, and getting the metal flakes (from the block) out of the engine. it has NOTHING to do with the ECM
