My Dyno Results.. Unsatisfied. (Graph)
I have the following mods:
Injen True Dual Angled Exhaust
MD 5/16" Plenum Spacer
JWT PopCharger
Helix Test Pipes
Here are my results: (sorry for the bad pic but you get the idea). It is corrected Im 5k above sea level.
I thought I was running a bit lean and a tune would get me a good amount of HP but it turns out I am not lean, and I don't think a reflash would get me too much.
Anyone have any suggestions? I thought I would at least be over 250whp with these mods.. I am so disatisfied.
JWT PopCharger
Helix Test Pipes
you are running too rich, up top, thus hurting your peak horsepower, 12:1 is hellified rich for N/A. headers will help you lean out of bit up top. even then i would still recommend a reflash. headers + reflash will get you up into the 270's maybe into the 280's.
Originally Posted by ZSpectrum
ya with wishful thinking. 270s maybe high 260s is more realistic.
Originally Posted by 350z_racer05
damn, I definetely need to get my car dynoed and tuned, I'll be getting a Utec within the next few months and hopefully with what I have I'll net 270+
Originally Posted by taurran
That looks about right to me. I had more mods than that when I was NA and made less power.
Forget headers. Just get a piggyback and tune it, you'll make your best gains by doing that.
Remove the JWT and install K&N and stock boxes. That will give you some power back. Your test pipes are causing your lean condition. Without a ECU tune, you won't be able to fix that.
JWT PopCharger
Helix Test Pipes
JWT PopCharger
Helix Test Pipes
Basic bolt on na mods will dissapoint. A tune will at least get u running more safe, but I wouldn't expect any big power gains.
Unfortunately there's no guarantee of power increase when combinng various breather mods on our cars.
Op, Don't let the dyno get to u, enjoy ur car.
Im not running lean though lol.. I have an 03 the stock boxes will make my power less.
Actually no they give you power back by putting the stock air boxes back in. After Market Intakes make you lose power or don't gain any. Most of the time it's the first part.
