Stripped Stud during spacer install--advice needed
Old Mar 29, 2008 | 05:42 PM
jran76's Avatar
jran76
Default ....
Please delete
Old Mar 29, 2008 | 11:58 PM
HR_Z-Ballz's Avatar
HR_Z-Ballz
A stripped stud is not a difficult repair. The studs are splined and can easily be removed by taking a rubber mallet and knocking them through the wheel hub. They are fairly inexpensive...
Old Mar 30, 2008 | 03:09 PM
jran76's Avatar
jran76
This was a small stud that threads into the lower plenum (there are 2 that have to be removed when installing a spacer). One came out no problem, and the other stripped reight away (using a 4mm 6 point socket).
I got it out but using a dremel (to grind down two sides for a better grip), and then I used a set of vice grips to break it loose and get it out.
Oh yeah, I did recently have to remove a wheel stud too (discount tire cross threaded a lug nut).
I started this to see if anyone else had the same problem. I was curious if the inverted E5 torx bit worked better, but after I got it out it was a moot point.
Pleask
Dec 21, 2021 03:17 PM
Dsowe
Feb 17, 2021 10:38 AM
SharX59
Sep 27, 2015 09:23 AM
