Ok I have radiator fluid everywhere...
Old Apr 26, 2008 | 12:03 AM
jubes's Avatar
jubes
Default Ok I have radiator fluid everywhere...
Ok guys, I seriously need your opinions on my situation...
For the past week, I've been hearing my cooling fan running continuously even when I'm running.. doesn't sound right to me, so I was planning on calling the dealer Monday since it's Friday afternoon and they are probably closed.
I drive down the freeway and I'm getting back from the movies and getting out of my car when I notice liquid all over the place... and it's comming from my car... I notice the smell of radiator fluid... and behold it is.
So I open my hood, and I notice the FREAKING COOLANT IS FILLED TO THE TOP OF THE CANISTER. WTF?!?!!?!?
Is this the reason why my fan has been running all the time? and the reason why my car is taking a leak on my driveway? Anybody have an answer? All suggestions or answers will be appreciated. Please help...thank you for hearing me vent.
Old Apr 26, 2008 | 05:06 AM
Sean's Avatar
Sean
when you turn on the heat do you get hot air?
Old Apr 26, 2008 | 06:31 AM
jubes's Avatar
jubes
I actually haven't tried the heater because it's like 80 degrees at night, I will try it now but I also have an appt at the dealership @ 8am.. so hopefully this can be resolved.
Old Apr 26, 2008 | 06:35 AM
Sean's Avatar
Sean
if you don't get heat, your thermostat is stuck, if you get heat you need to check for air in system
Old Apr 26, 2008 | 04:05 PM
jubes's Avatar
jubes
Well, I took it to the dealer...
and it started to overheat when I got there... they called me back and said my radiator was fried... I really don't understand why my radiator would be fried if I just had it service may be two weeks ago, with a 30k major service package. I mean they flushed it, so wouldn't they be able to see something wrong when they did that?
Well now I have to leave it over til monday so they can order the part, which totally sucks.. Hearing the cooling fan run every minute probably was the signal to get it checked..
I appreciate the views guys.. at least I get to learn something valuable...
Old Apr 26, 2008 | 04:12 PM
Sean's Avatar
Sean
Am I the only one that thinks this is a case of a dealer making crap up to get paid?
I am going with Air in the system.
Old Apr 26, 2008 | 04:43 PM
Corradoslc7's Avatar
Corradoslc7
Yeah I agree w/ Sean. It's too coincidental that 2 weeks after a radiator flush your car starts overheating. They definitely didn't bleed the system after they filled it up.
Old Apr 26, 2008 | 04:46 PM
Sean's Avatar
Sean
you also ommited the flush info from your first post.
Old Apr 26, 2008 | 10:05 PM
Grommit's Avatar
Grommit
You got air... I have the SAME problem right now. Been bleeding air pockets for two days now!
Old Apr 26, 2008 | 10:16 PM
Mr_pharmD's Avatar
Mr_pharmD
does your coolant tank look like milk shake or crap in it? If so, it might be a blown headgasket.
Old Apr 26, 2008 | 10:45 PM
jubes's Avatar
jubes
I didn't think the 30k service would've been the possible source for my problems til I started hearing other people's opinions about the whole situation...
I honestly and truly feel the dealership that did my 30k, which happens to be the same one replacing my radiator, screwed me over...
I don't know about the air bubble situation and how that works, but if thats why it causes all of my radiator fluid to shoot back into the canister, then I definitely had air bubbles...
as for the appearance of the liquid, it looked normal, like the 50/50 mix of radiator fluid and water...
I feel so naked without my Z..
Old Apr 27, 2008 | 04:31 AM
Sean's Avatar
Sean
I hope they are going full warranty or you will feel even more naked.
Old Apr 28, 2008 | 06:15 AM
gothchick's Avatar
gothchick
might have a leaky head gasket now from overheating...
Old Jun 19, 2008 | 04:48 AM
jdl350z's Avatar
jdl350z
If the heater doesn't work and its the thermostat would that also be the reason it is eating up radiator fluid??? (no leaks on the ground,temp goes up and down when driven)
Old Jun 19, 2008 | 05:33 AM
terrasmak's Avatar
Air in the system , and the dealer is going to charge you for there f up. Fried radiator LOL , they either leak or get clogged after years of use.
lapham3
Oct 7, 2022 03:15 PM
burglapfd
Dec 6, 2020 01:04 PM
SharX59
Sep 30, 2015 10:54 AM
