VLSD swap
Old Apr 26, 2008 | 01:07 PM
bovi's Avatar
bovi
Default VLSD swap
I have a base model 04 and i'm always spinning 1 fu&&$() wheel at the time. I have a good price for a almost new VLSD that came from a 07 Z, will it fit?
Old Apr 27, 2008 | 12:20 PM
Gsedan35's Avatar
Gsedan35
It will fit, but doing it via a parts swap doesn't make economic sense by the time you add in all your costs. You have to buy VLSD stub axles and consider the labor cost's to install it all. Then in the end, you still have a oem limited slip system that isn't very good. Getting a fully assembled pumpkin that already has the VLSD installed makes the most sense cost wise, but since you have a 07 IIRC you have a different final drive ratio vs previous years, finding a 07 diff might be kinda difficult. IMO, spend more and get something like a Cusco RS LSD.
Old Apr 27, 2008 | 12:46 PM
Escobar's Avatar
Escobar
well said ^; I did the same thing, just got the whole pumpkin and bolted it up. I wouldnt recommend buying the internal vlsd and putting it in, if your gonna go that route, do what Gsedan said and get an aftermarket clutch type.
Old Apr 27, 2008 | 01:38 PM
Corradoslc7's Avatar
Corradoslc7
Why don't you get the Quaife, it's a direct bolt in for all base models?
Old Apr 27, 2008 | 03:03 PM
bovi's Avatar
bovi
Maybe but its about 1500$.....Bit pricy for what i do with the Z. I can get a 07 vlsd for 200$
Old Apr 27, 2008 | 08:41 PM
kramykram's Avatar
kramykram
If you can do all the work yourself then go for it but once you pay the 200 plus shipping for the vlsd 150 each axle stub plus shipping. labor if you have to take it somewhere. you would of come out cheaper just buying the whole pumpkin. even if you do the work yourself it will still come out cheaper to buy the used pumpkin with the vlsd.
Old Apr 28, 2008 | 09:54 PM
bovi's Avatar
bovi
why do i need to replace the axles and everything?
Old Apr 28, 2008 | 10:00 PM
deezz's Avatar
deezz
Is there a good source to buy the entire pumpkin for the base? Would like to do this but definitely want to just bolt the thing right up.
Old Apr 28, 2008 | 10:02 PM
Escobar's Avatar
Escobar
yes, contact Jim@TurboToys
Old Apr 29, 2008 | 03:40 AM
WalkerT's Avatar
WalkerT
Professional
You need to replace the stub shafts because they are different lenghts on the VLSD.
The base stubs are the same size.
I have these for sale and you can see in the pic the stub shafts for the VLSD are not the same size.
https://my350z.com/forum/texas-marketplace/340401-fs-07-open-diff-and-vlsd-and-one-half-shaft.html
Old Apr 29, 2008 | 06:35 AM
deezz's Avatar
deezz
THX
Old Apr 29, 2008 | 09:33 PM
Escobar's Avatar
Escobar
no problem, Jim is a good guy.
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
SpartanZ32
Oct 22, 2015 09:36 AM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
SharX59
Sep 27, 2015 09:23 AM
