www.phantomgrip dot com LSD alternative.
Old May 9, 2008 | 09:36 AM
JasonZ-YA's Avatar
JasonZ-YA
Default www.phantomgrip dot com LSD alternative.
Any of you guys check this out.????
http://www.phantomgrip.com/catalog/p...roducts_id=195
"how to" slide show:
http://www.phantomgrip.com/carmth.html
-J
Old May 9, 2008 | 09:38 AM
Asian Invasian's Avatar
Asian Invasian
I wouldn't really trust it considering that they can't even get the years right on the 350z...
Old May 9, 2008 | 09:46 AM
Motormouth's Avatar
Motormouth
just weld your diff then. much cheaper.
or you know, buy a real lsd.
Old May 9, 2008 | 10:20 AM
06blueZ's Avatar
06blueZ
doesnt look like a very good solution at all... all it is doing is loading the side spider gears, there arn't even any clutches there in the stock open diff, so that is just putting a lot of pressure against the side gears in a way they were not designed for. This will cause the spider gears to wear much faster, its just going to be metal on metal grinding where the spring plates go in..
looks similar to a powertrax, but since it still uses the stock side spider gears, it's crap. i wish powertrax would come out with something for the base 350's...
Old May 9, 2008 | 08:43 PM
Asian Invasian
Isn't it around the same price to just buy a real LSD like motormouth said?
Old May 9, 2008 | 09:33 PM
Escobar's Avatar
Escobar
yeah, i guess it depends on which one you get, you can buy a stock vlsd for around that. this mod isnt great, it will end up destroying your diff. as motormouth said, it would be better to just weld it.
Old May 9, 2008 | 09:37 PM
turismo's Avatar
turismo
I think alot of Hondas use them
Paul.
Oct 16, 2015 07:34 PM
seagrasser
Oct 11, 2015 03:27 PM
RiujinZero
Sep 25, 2015 01:19 PM
3vilbunny
Sep 13, 2015 12:31 PM
