Rpm Drop
I have 6-speed Performance Model 350z. With 6K with a Grounding Kit (from InZane).
Last weekend while the car was idle-ing I heard the car sputter but didn't pay much attention to it. Today I drove the car and I noticed that when I stop the RPMs drop to about 500 for a split second then come up to about 700 - 750. Anyone what could cause this.
thanks.
thanks.
thanks.
thanks.
Cars without GKs do this too. It is called having a ton of moving parts. This isn't a computer that does the same thing every time. There is something called vaccuum that can vary depending on things as simple as AC on or off or your foot on the brake, etc. Vaccuum can easily affect the idle but it recovers. Don't worry you are driving a car...
I've had the GK since about 500 miles and this is the first time I noticed RPM drop. May be one of the wires came loose. Today I went to get gas. on the way to the gas station it did it once. I drove the car for a while after getting gas and it hasn't done it since. It could be that the gas cap was not tighted all the way.
If it does it again I'll check the Grounding Kit
thanks for your help I'll keep you guys posted.
your grounding wires ARE NOT LOOSE.....my car does the same before and after i had my grounding kit installed.
When coming to a stop, It goes to 700rpm then drops to 500, but sometimes the opposite happens, 500 then 700 then back to 500.
This is normal. Dont worry.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
