Pulleys ???
Old May 20, 2008 | 07:02 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Default Pulleys ???
I bought a used ur crank pullys from one member here, i installed the idler and alternator, but stup*d crank pully didn't come off, so i decided just leave it like that.
here is my question, is that ok to just use lightweight idler and alternator with stock crank pully? or should i replace back to stock?
-JLee
Old May 20, 2008 | 08:15 PM
GrayG35's Avatar
GrayG35
its fine
Old May 21, 2008 | 04:51 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
^thanks
Old May 21, 2008 | 08:14 PM
Ztalker's Avatar
Ztalker
use a 24" breaker bar....your crank pulley will come off.
Old May 21, 2008 | 08:30 PM
phreaktor's Avatar
phreaktor
Design Engineer
isnt the whole point to lose 5lbs in the crank pully?
Old May 21, 2008 | 08:32 PM
lbz's Avatar
lbz
The crank pulley is a bear to get off. I had to use a breaker bar and a 3 foot section of aluminum pipe from Home Depot to get mine off. If you do go for it you will need to replace the belts.
Old May 21, 2008 | 09:03 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
what do you mean by replace the belts?
Old May 21, 2008 | 09:04 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Thanks for info, will try my next day off.
Old May 21, 2008 | 09:06 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
i kno, i ended up just installed idle/radi pullys...
Old May 22, 2008 | 02:03 AM
350z-Jim's Avatar
350z-Jim
I have a UR crank pulley and lightweight flywheel and the car revs up a lot faster then it does stock, really makes a difference. The rev action at idle when you blip the throttle is much faster than before.
Old May 22, 2008 | 02:21 AM
teh215's Avatar
teh215
Smaller pulley uses a shorter belt.
Old May 22, 2008 | 04:19 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Edit: i took it to local shop, still didn't come off. I guess my car loves stock crank pully lol..
Old May 22, 2008 | 04:26 AM
teh215's Avatar
teh215
Edit: i took it to local shop, still didn't come off. I guess my local shop doesn't know what they are doing..
Fixed
Old May 22, 2008 | 04:40 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Originally Posted by teh215
Fixed
Old May 22, 2008 | 12:51 PM
Jeff92se's Avatar
Jeff92se
How did you manage to change the Alternater pulley?
Old May 22, 2008 | 07:31 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
bolts was easy. Just a crank pully.
Old May 22, 2008 | 08:08 PM
n1cK!'s Avatar
n1cK!
Infiltrator!
you didn't have to remove the alternator?
Old May 23, 2008 | 06:26 AM
Highway Riding's Avatar
Highway Riding
I hear it's a reall SOB to get the old pulley's off kinda of like z headers.. Is this really worth it?
Old May 23, 2008 | 07:40 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
I didn't
Old May 23, 2008 | 07:59 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Old pulley
I just took them off,
http://www.unorthodoxracing.com/inst.../04100150_.pdf
i got an idea from here, also from other member's pictures.
You can find more DIY from G35driver.com
worth it?
After i installed pulleys, i realized that 'it's NOT that worthy for $'. But i got it for good deal + time to change my belts anyway. Lot of people said that they felt from their butt dyno, but my butt dyno felt more power from MD's spacer lol
-JLee
