Oil pressure?issue?
Old Jun 3, 2008 | 10:41 AM
XM 1's Avatar
Default Oil pressure?issue?
yeah i know...use the surch button....i did
but this seems to be some different sort of issue(maybe)
today i went out for a little "test drive" (new hood) and i noticed that my guage read out was at about 100 and stayed there even in idle
thought ok maybe you drive around an have a look what happens(also happend the last time i was driving but not that high).after several km it was still at 100(idle at around 50-60). after about 10-20km all of the sudden it was "normal" again full throttle about 70-80, idle at 40.drove for about 1,5 h and nothing still everything normal.
now my question is whatīs the issue with that?? bad oil pressure sensor??
had a oil change about 200km ago (stealership did it, and cracked one of the side steps ).oil level is at H.donīt drive the car that often about 2-3times a week(just a fun ride for good wheather).
any guesses???will def have a look under the car on the weekend to make sure the stealership didnīt messed up something
Old Jun 3, 2008 | 12:16 PM
rcdash's Avatar
rcdash
oil is thicker when cold.
Old Jun 3, 2008 | 12:25 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
yeah there have been alot of threads on oil pressure low its because its getting hot oil gets thinner if your that worried you could use a thicker oil. Or in your case maybe a thinner oil. My car does that but i use Mobil 1 0w-40 so i have to let it warm up, but when im at the track i usually have "normal" oil pressure when i come off where as most people have low oil pressure.
Old Jun 4, 2008 | 06:57 AM
XM 1's Avatar
well thx for quick reply.....just what i thought ....but itīs still a little bit worrying...but iīll think iīll have to deal with it.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
350z82
Oct 1, 2015 06:25 PM
