MOCAL Sandwich adapter - proper fittings question
Old Jun 4, 2008 | 06:42 AM
rcdash's Avatar
rcdash
Default MOCAL Sandwich adapter - proper fittings question
So I've read that 1/2" NPT fittings are inappropriate for the Mocal sandwich plate and Mocal in fact provides 1/2" BSP to -8AN or -10AN fittings. Great I can get those two. My cooler accepts a 3/8" hose barb.
None of the DIY guides use anything other than 5/8" hose and they use NPT fittings (where Mocal recommends against it).
So without using a lot of adapters, I am looking for a 1/2" BSP to 3/8" hose barb fitting or a -8AN female to 3/8" hose barb. I've tried Summit Racing and JEGS with no luck...
Any other good sites with fittings? If only the Mocal oil adapter took NPT fittings it would be a snap. Should I just tap the ports to 1/2" NPT?
Old Jun 4, 2008 | 06:49 AM
JonnyC's Avatar
JonnyC
I think you should be able to find any fitting...ever...here - http://www.mcmaster.com/
Old Jun 4, 2008 | 08:39 AM
Drewer's Avatar
Drewer
+1 McMaster-Carr has everything.
Old Jun 4, 2008 | 10:57 AM
nlzmo400r's Avatar
nlzmo400r
i THINK i used the mocal adapter. But I used teh 1/2" to -10an adapters as well. I have nylon braided -10an lines running to my mazda oil cooler. With oil, you should really consider the larger -10 lines
Old Jun 4, 2008 | 12:58 PM
rcdash's Avatar
rcdash
why when the bottleneck is flow through the cooler, not the lines?
the issue with the 1/2" fitting is that the Mocal sandwich adapter has straight threads, not tapered. I am probably just going to tap it to tapered... Then I can safely use a 1/2" NPT to barb hose fitting.
Pleask
Dec 21, 2021 03:17 PM
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
Fixxxercask
Nov 9, 2015 11:10 AM
