whistling/squeaking noise while accelerating?
Old Jun 5, 2008 | 08:25 AM
cjeezy's Avatar
cjeezy
Default whistling/squeaking noise while accelerating?
Is there suppose to be a sort of whisting noise at the front of the car when accelerating? I notice this odd sort of noise when my windows are down that kinda sounds like a cross between a whistle, belt sqeaking and an air leak when I press in the gas about 50%. If I floor it, there is no noise though. This happens in any gear. The car does have a pop charger on it. Could that be it, or should I have the shop check it out? I hate going to the shop here, and I do not have a stock air box to test to see if the pop charger is the cause. Mechanically, it feels like it's is running perfect. Just an annoyance.
Old Jun 5, 2008 | 10:06 AM
track1z's Avatar
track1z
If you just put a new intake and its making that noise it may be normal. NOW if it cam out of no where. It sounds to be a vacuum leak it needs to be fixed now. Its probable runnning really lean IFFFFFF its a vacuum leak.
Old Jun 5, 2008 | 10:09 AM
cjeezy's Avatar
cjeezy
I've only had the car for 2 months now and it made that sound ever since I purchased it (pop charger came with the car). At first, I thought it was normal, but now it's starting to annoy the crap out of me since I've been driving with the windows down more often.
Old Jun 5, 2008 | 12:41 PM
Swiffer's Avatar
Swiffer
Yep, its likely from the popcharger. Mine makes a slight whistling sound occasionally.
Old Jun 5, 2008 | 12:44 PM
gothchick's Avatar
gothchick
You have the front wheel drive version of the Z. You are spinning your front wheels.
Old Jun 5, 2008 | 01:52 PM
cjeezy's Avatar
cjeezy
HAHA! Maybe its my 4 cylinder engine!
Old Jun 6, 2008 | 07:34 AM
cjeezy's Avatar
cjeezy
Took car in to shop today. They said it was my popcharger. Man does that thing make some noise!
Old Jun 18, 2008 | 03:02 PM
SCARECROW BEATS's Avatar
SCARECROW BEATS
+1
Old Jun 18, 2008 | 03:04 PM
surfcity40's Avatar
surfcity40
IBTL. Aftermarket intakes whistle. Some folk kind of enjoy it
Old Jun 18, 2008 | 03:05 PM
marques1's Avatar
marques1
popcharger is the culprit but is normal. You will start hearing the whistle noise at about 3,500 rpm's, watch.
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
