5at
Old Jun 15, 2008 | 04:12 PM
jgregory124's Avatar
jgregory124
Default 5at
Hey guys, trying to get some correct info. I thought the autos had the lsd just like the manual but have been told by a shop that the autos dont have a lsd.
any info would be great
Old Jun 15, 2008 | 04:23 PM
bizcotch's Avatar
bizcotch
Then, Nissan ripped me off on my enthusiast. my 5at has lsd...i hope
Old Jun 15, 2008 | 04:31 PM
stein's Avatar
stein
It's depends on the model, I don't think the base model come with it. Search for model specs.
Old Jun 15, 2008 | 05:36 PM
jgregory124
I have but a parts store that sells factory nissan parts told me that......by the way base only comes in manual
Old Jun 16, 2008 | 03:35 AM
Z04's Avatar
Z04
tell that "parts store that sells factory nissan parts" that they are full of crap
Old Jun 16, 2008 | 08:28 AM
jgregory124
ok.......
Old Jun 16, 2008 | 09:01 AM
JOEGYVER's Avatar
JOEGYVER
Base model, regardless of manual or auto, not equipped with LSD. I have 07 touring 5at equipped with LSD, so enthusiest should as well. The auto does have a different LSD than the 6MT though. They function the same, both viscous, but the flange for the ring gear is shifted over 10mm for the 5at due to the different gear ratio of the 5at (Pinion gear is bigger by one tooth, causing ring to have to shift). The pumkin is identical. If you wish to install different gears, you need a 6mt differential. I just put 4.08s in my 5at pumkin, and bought the nismo differential so they would work. No need for a pumkin swap, but not an easy job! Hope this helps.
whosdady
Jan 2, 2014 04:40 PM
whosdady
Mar 10, 2004 11:40 PM
dlt1cy
Feb 18, 2004 03:50 PM
whosdady
Nov 27, 2003 05:42 AM
EL Diablo
Oct 14, 2003 03:23 PM
