Greddy 15mm Oil Catch Can Install
Old Jun 16, 2008 | 06:40 PM
wannabuy350z's Avatar
wannabuy350z
Default Greddy 15mm Oil Catch Can Install
Hello Everyone,
let me start by saying that most of you think there is no way it will fit, well it did. after looking the engine bay for a while. I decided the spot where I was going to put it, not this can is much larger than the squar type.
I would like to say, the reason why I place it there was because of the JWT system leaves no room for anything.
The oval shap of this can is a pain!
But after work today I tackled it and its good.
Items Needed:
  • 4ft of .5" tubing
  • Ties
  • Flat head screw driver
Steps:
  • Remove Strut bar 14mm
  • Engine Cover 10mm
  • DBW assembly 10mm
  • Place the catch can up-right (after reinstalling the DBW assembly it will hold it in place.
  • install one side of the tube on the right inlet of the can, tie it firmly. and run the tube along the spark coils till you reach the manifold pipe.
  • Cut the tube with a knife (or what ever sharp tool you got) give it some slack
  • then the rest is commen sense.
Thats basically it, reassemble everything. shouldn't take more than 30 minutes (no power tools used)
Old Jun 16, 2008 | 10:36 PM
wannabuy350z
should this be posted somewhere else?
I need to clean my engine bay
Old Jun 17, 2008 | 01:03 AM
350ZTheStandard's Avatar
350ZTheStandard
My car is in paint & I will post up my installation of the Greddy catch can in a different location in the 350Z, when my baby is back home. I have the square catch can, we had to fab up a bracket, thank God I have a Nismo CAI.
I truly looked damn hard at the firewall for a mounting point, thought better of the idea in the end. How do you check the oil level in your mounting location???
Old Jun 17, 2008 | 08:28 AM
wannabuy350z
^easy, you can see it clearly from the side.
Old Jun 17, 2008 | 08:30 AM
Nexx's Avatar
Nexx
:+1
here is a picture of where Sharif placed mine.
Old Jun 17, 2008 | 09:06 AM
rcdash's Avatar
rcdash
The JWT kit has a pipe right there.
There is no good place for a vertical catch can with the jwt kit. You can fit one underneath the air filter, but it will be hidden from view.
I can't put one in the back by the firewall because like Nexx, my FPR for my CJM return fuel system sits right there as does the 5AT tranny dipstick.
Long thin and horizontal is the only way to go...
Old Jun 17, 2008 | 09:13 AM
wannabuy350z
^yea, that was the problem, you its still managable with the JWT if you have the squar style can.
Old Jun 17, 2008 | 03:05 PM
superchargedg's Avatar
superchargedg
Damn Noobs
I dont know how the z would fit but i had to mount mine like this.
Old Jun 17, 2008 | 04:49 PM
Nexx's Avatar
Nexx
we both need to get rid of our mushrooms of death.
Old Jun 17, 2008 | 11:13 PM
wannabuy350z
clean engine bay.
Old Jun 18, 2008 | 06:50 AM
gothchick's Avatar
gothchick
Yeah, it's hard to find a good place to mount a standard catch can. So I ended up going with a smaller home-made unit instead.
Attached Thumbnails Greddy 15mm Oil Catch Can Install-dsc02359-1-.jpg   Greddy 15mm Oil Catch Can Install-dsc02361-1-.jpg   Greddy 15mm Oil Catch Can Install-dsc02368-1-.jpg
Old Jun 19, 2008 | 11:39 AM
wannabuy350z
^thats awesome. I wish we had a bigger engine bay
apex locator
Jul 23, 2021 02:27 AM
