Front main seal
Old Jun 26, 2008 | 02:06 PM
redman333's Avatar
redman333
Default Front main seal
I have had an oil leak for awhile now, I originally thought it was my turbo return line cause it had a kink in it and was leaking. I fixed that and am still having a leak. Its pretty bad now. Almost 4 quarts in 3k miles.
I'm pretty sure it the front main seal.
Does any one know if I need any special tools for that. I have a pully puller for the pullies. Is there anything else though.
Old Jun 26, 2008 | 02:27 PM
Hoooper's Avatar
Hoooper
ummm, nevermind. and it wont let me delete so here we are....
Old Jun 26, 2008 | 03:07 PM
redman333's Avatar
redman333
ok
Old Jun 26, 2008 | 03:14 PM
DavesZ#3's Avatar
DavesZ#3
No special tool needed for the front seal. You can hook the edge of it with a small screwdriver or something to get it started.
Old Jun 26, 2008 | 03:20 PM
Hoooper's Avatar
Hoooper
so it is just like a rear main seal? thats what i was starting to think, you just tap the new one back into place around the crank. so its like a wheel bearing dust seal. its one of those things that if youre lucky it will take a half hour to do the actual seal part, but could end up taking 3 hours if its a bish to get out, like a pilot bushing
Old Jun 26, 2008 | 03:53 PM
redman333's Avatar
redman333
Awesome, thanks guys. I just wanted to make sure before I started to do the project cause I'm going to be doing the work in my parents garage cause I live in an apartment complex, so I didn't want to get it apart and find out I need something else.
Old Jul 5, 2008 | 08:32 PM
redman333's Avatar
redman333
Now, I took everything apart and found out its not my seal that is leaking. The actual crank pulley has a crack right near the keyway slot. So if anyone happens to have one laying around hit me up and I will be willing to take it off your hands.
Old Jul 6, 2008 | 04:43 AM
cbr900son's Avatar
cbr900son
I just replaced my stock crank pulley with a light weight one. Its off a 06 - tho i dont think it matters. Let me know if u need it.
Old Jul 6, 2008 | 03:20 PM
redman333's Avatar
redman333
Thanks for the reply, but I'm looking for something a little more local first.
Obadabot
Jun 18, 2023 11:31 PM
350z82
Oct 1, 2015 06:25 PM
