Has anyone changed there Final Drive Ratio?
Old Jul 21, 2003 | 07:09 PM
OCG35Coupe's Avatar
OCG35Coupe
Default Has anyone changed there Final Drive Ratio?
Here is what i think i know.
The 350Z's final drive model is R200V or R200?.....Final Drive Ratio is 3.538 to 1 for 6/MT and 3.357 to 1 for the 5/AT.
1997-1998 240SX's have final drive model R200V with a 4.083 to 1 Final Drive Ratio.
Non Turbo 300ZX's have final drive model RS00V with a 4.083 to 1 Final Drive Ratio.
1995-1996 J30's have final drive model RS00V with a 3.916 to 1 Final Drive Ratio.
http://www.nissanperformancemag.com/...y03/ask_sarah/
Final Drive Model for 350Z and 240SX listed
http://www.vibratesoftware.com/html_...rive_axles.htm
http://www.cautioncreativity.com/briand/lsd.htm
Are swaps possible? Im a noob, but those fast domestic owners are always talking about gears!
Old Jul 21, 2003 | 07:58 PM
JimH's Avatar
JimH
Default Re: Has anyone changed there Final Drive Ratio?
I swapped my 5AT final for the 6MT final back in April down at Z1 Motorsports. AFAIK, I am the only such swap to this point. And yes, it has given me back some low end grunt at the expense of 1-2 mpg loss. No big deal. I p/u between 2 and 4 tenths (hard to average with wx changes) in the 1/4 and that IS a big deal! A worthwhile swap.
I do wish I knew if the gears from the 97-98 would fit. Now there's a good swap if you like to run the 1/4 more than cruise the interstate!
Thanks for the info and I am going to ck. out the possibility of the even lower gears from the 97-98. If you hear of the possibility of a match, please post. Thx, Jim
Old Jul 21, 2003 | 08:27 PM
OCG35Coupe's Avatar
OCG35Coupe
Default Re: Re: Has anyone changed there Final Drive Ratio?
Is there anyway to counter the lost MPG? For instance the 5/AT 350Z has a 5th gear (OD) of .834:1
The 6/MT has a 6th gear (od) of .794:1
An LS1 Camaro/Vette/Firebird has a 6th gear of .50:1 which allows the engine to cruise at 1750 RPM's and achieve around 30 MPG's in 6th gear
Can we change the 5th gear ratio for the 5/AT or the 6th for the 6/MT?
Old Jul 21, 2003 | 09:20 PM
OCG35Coupe's Avatar
OCG35Coupe
Looks like the JDM 180SX (S13) also used a R200V "final drive model"...It's the 180SX with the CA18DET engine.
That 180SX (S13) has a Final Drive Ratio of 4.363:1
The RS13 (180SX) also has a Final Drive Ratio of 4.363:1 but has taller gears throughout.
http://www.asahi-net.or.jp/~dy7n-itbs/silvia_data.htm
There has got to be more to it than just finding nissan cars that also used the final drive model R200V right?
My fantasy gear setup
1st 3.50:1
2nd 2.35:1
3rd 1.55:1
4th 1.05:1
5th 0.55:1
Final Drive 4.363:1
Old Jul 22, 2003 | 01:56 AM
Juztin's Avatar
Juztin
I've also been looking at swapping the final drive ratio. I'm moving up to 20" rims in the back, and I could definately use a 4.x:1 to counter act the lost time as much as possible. I woudl be happy if I could break even and get around the same accel w/ 20" as I was with my 17"s. I took a look at some of your links:
R200 MT 3.538
R200V MT 3.357
R200V AT 3.357
I know the base model (which I have) has the final drive ratio of 3.538:1. I take it the trailing "V" means for cars that have the viscious LSD right? In which case they do have the lower final drive ratios.
I think the re-gearing of all gears would be a bit more $$$ as someone would have to crack the tranny and replace the gearing. I'm thinking about going to a few tranny shops around here ot see if it will be possible to swap out the final drive with something around 4:1 to 4.5:1. Anyone else here in the forum done something like this yet? Any ideas?
--Justin
Old Jul 22, 2003 | 01:58 AM
Juztin's Avatar
Juztin
So a base model should have the R200
Old Jul 22, 2003 | 09:48 AM
OCG35Coupe's Avatar
OCG35Coupe
I thought all 350Z's came with VLSD's?
http://www.autoweb.com.au/start_/sho...wsarticle.html
the R200V with 3.357 is for the 5/AT
The R200V with the 3.538 is for the 6/MT
The the 180SX has an R200V with a 4.3x final drive
Old Jul 22, 2003 | 09:50 AM
JimH's Avatar
JimH
Default VLSD
All but the base come w/VLSD. Regards, Jim
Old Jul 22, 2003 | 10:14 AM
cbsuper's Avatar
cbsuper
Jim, who did you you talk to at Z1 for changing your ratios?
Old Jul 22, 2003 | 10:16 AM
JimH's Avatar
JimH
Default Z1 Motorsports
Talk to Russell who is the owner and a very personable guy to deal with. Regards, Jim
Old Jul 22, 2003 | 02:44 PM
OCG35Coupe's Avatar
OCG35Coupe
--Justin
Ok so no re-gearing all the gears...All i really want re-geared is my OverDrive a.k.a. 5th gear in the 5/AT.
And a Final Drive Ratio of 3.9x - 4.3x:1
350Z_Al
Oct 29, 2020 07:44 PM
3vilbunny
Jul 18, 2017 05:10 PM
kyin
Oct 15, 2015 05:54 AM
Stevo Z
Oct 3, 2015 09:14 PM
