after installing my aftermarket steering wheel...
Old Jun 29, 2008 | 02:36 PM
NH01's Avatar
NH01
Default after installing my aftermarket steering wheel...
Hey all,
I just installed a personal steering wheel.. and I did not do the airbag light trick.(this probably has nothing to do with it)
Problem..
after starting the car.. put in first gear and go forward for a few sec (does not matter how fast) i feel the traction control turn on for about a second or so.. then next thing is vdc off light is on..+ SLIP light turns on..
so then i tried starting the car.. turning off vdc first. .then drive.. after a few seconds.. the SLIP light turns on... but at least the traction control didnt kick in and slow the car down.
I actually like the fact that now my traction control is FULLY off and i still have ABS..(when u pull out traction control fuse..abs will be de-activated as well)..i just love it.. but I just want to know what happened? Why is it doing this?
Thanks
NICK
Old Jun 29, 2008 | 04:28 PM
Zivman's Avatar
Zivman
there is a sensor in the column that you did not keep in the proper position that the VDC uses. to put it bluntly, you are kind of f^cked. it is a pain in the @ss to guess at is proper position. Your best bet might be to take it to the dealer to zero it out
Old Jun 29, 2008 | 05:03 PM
kramykram's Avatar
kramykram
Originally Posted by NH01
Hey all,
Problem..
Thanks
NICK
The adjustment is easy if you have a works bell hub. i first used a momo which sucked *** as it did not allow for the vdc sensor to sit in the right place. i then purchased a wb hub and i just put it all together, drove my car without the stearing wheel nut in place in an empty parking lot. i just kept adjusting it a little at a time, turning off and restarting the car and driving till i had it where it needed to be. its really not to much trouble.
Old Jun 29, 2008 | 05:12 PM
Ruthless18x's Avatar
Ruthless18x
+1
You moved the sensor.
Old Jun 29, 2008 | 08:36 PM
NH01's Avatar
NH01
Thanks guys..
where is the vdc sensor?is it that nipple thing that sticks out when u remove the OEM steering wheel?
and how do u hook up that air bag trick? there is orange and yellow wire for airbag.. my momo hub came with a airbag trick(+2amp fuse at the end.)... do i need 2 of these and plug it into both yellow and orange airbag wires?
Old Jun 30, 2008 | 01:56 AM
kramykram's Avatar
kramykram
Thanks guys..
Yes its the nipple thing. yes you need another 2amp fuse.
Old Jun 30, 2008 | 07:32 AM
NH01's Avatar
NH01
Cool
Thanks alot man..
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
SharX59
Sep 27, 2015 09:23 AM
