Slave cylinder 2003 vs 2004+?
Old Jul 3, 2008 | 11:13 AM
Blackbird CPV35's Avatar
Blackbird CPV35
Default Slave cylinder 2003 vs 2004+?
http://www.courtesyparts.com/betasit...5_778_781.html
i may need to replace my slave cylinder, does anyone know if there is a difference between these 2 cyl?
they are both priced differently but appear to be identical
Old Jul 3, 2008 | 12:15 PM
Z04's Avatar
Z04
did you even look at the part number?
psst, they are the same
Old Jul 3, 2008 | 12:36 PM
citymunky's Avatar
citymunky
I would try the re-build kit first. (Yes Nissan makes one, I re-built mine)
Old Jul 3, 2008 | 01:40 PM
Blackbird CPV35
thats what i thought but then the part number is different on the other page. hmmm
Old Jul 4, 2008 | 10:33 AM
pmohr's Avatar
pmohr
The part code is the same, not the part number.
I imagine they are interchangeable, but who knows until they try.
FAST shows them all to be the same bore (3/4"), mounting locations are the same...
Old Jul 5, 2008 | 04:54 AM
SteveZ's Avatar
SteveZ
The obvious part that jumps out at you is the first has a mounting bracket or shield, #30671, the second does not show that part. It's likely a difference in mounting the slave and the cylinder itself appears identical.
I replaced mine in early 2007, for about $30 I can't see why you'd bother to rebuild it, the seals were all shot in mine. One day the clutch just didn't return and all the fluid was on the driveway. I pulled it apart and it just looked "cooked" - pieces of black stuff in the fluid, seals coming apart - at 30k miles.
They're exposed to a lot of heat in their mounting location. Check other threads about "clutch fluid overheating" or "clutch does not return when it's hot out". Highly recommend some high temp fluid (e.g. Motul) when you replace it, it's a known issue the 2003-2004 routing causes problems. Notice how baked the "heat shield" material on my line looks - it's too close to the cat and exhaust.
Mine on my early 2004 (build date Oct 2003) V35/G-Coupe mounts externally, has a cover that serves as a mounting bracket similar to that diagram - go look under the driver's side and see what you have. I thought for some reason later models moved the slave location on the Z33 and V35, either elsewhere outside the case, or inside the trans case itself.
07ZEKE
Aug 23, 2021 09:15 PM
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
