Can I change my solid motor mount like this??
Old Jul 11, 2008 | 02:11 PM
doreamon50's Avatar
doreamon50
Default Can I change my solid motor mount like this??
Hey guys, I'm planning to install a set of Solid Motor Mount tomorrow, and I'm planning to raise one side of the car and loosen the bolt on the OEM mount, then I'll put a wooden block under the oil pan, and slow lower the car, so the engine will raise enough room for me to change the mount. Do you guys think this will work??
Old Jul 11, 2008 | 03:03 PM
SpoilsofWar's Avatar
SpoilsofWar
As someone who has changed to solid motor mounts, I would not recommend that method at all!
That oil pan is only stamped steel, and probably about 1/8th inch thick or less.
Old Jul 11, 2008 | 04:25 PM
track1z's Avatar
track1z
THAT pan will crack bend dent! Do what you want tho.
Old Jul 11, 2008 | 07:03 PM
gothchick's Avatar
gothchick
Don't lift the engine by the pan...
Old Jul 11, 2008 | 07:47 PM
411Z's Avatar
411Z
dont forget to solid mount the tranny as well. do one, and you must do both. i know sometimes you can get lucky but if you not, it gets really ugly. and be ready for the rumble. its no longer a smooth ride!
Old Jul 11, 2008 | 08:31 PM
SpoilsofWar
I'm not sure where you got that from. The majority of people on this forum running solid motor mounts (including me) are still using the stock transmission mount.
Who told you otherwise?
Old Jul 12, 2008 | 03:22 AM
track1z's Avatar
track1z
It would be common since you can change the transmission out aswell. Take your old one down to a couple of machine shops not all do custom fab.
Old Jul 12, 2008 | 08:45 AM
SpoilsofWar
I know they make aftermarket transmission mounts, what I am questioning is 411Z's statement that you must change to a solid trans mount if you do the motor mounts - which I know from personal experience is not true.
The guy who built my engine, Scott of SVRT, is the same guy who made most of the solid engine mounts in use for the Z... And he never told me that, either.
Old Jul 12, 2008 | 11:35 AM
track1z's Avatar
track1z
I don't see it being a must,BUT why not?
Old Jul 12, 2008 | 04:57 PM
411Z's Avatar
411Z
my bad on the whole MUST word... like i said, you can get away with it. and it sounds like alot of guys have. and its not that someone told me that, i speak from experience. back when i had my 68 camaro about a year and a half ago, (8.80 1/4, @155, purpose built) i ran a rubber tranny mount w/solid motor mounts. my buddy camaro was the same way. at about 1000', the rear end of his car slid out just a bit, which obviously twisted things aroung just a bit. well i guess the tranny wanted to wiggle in its rubber mount, and it snapped the tail shaft clean off of his th400. the next day i had a solid mount on my tranny. just somethin to think about, cause it can happen.
Old Jul 14, 2008 | 09:24 PM
SnyperZ's Avatar
SnyperZ
apples to oranges..do you have any idea the difference in torque when comparing an 8 second camaro vs a 350...even a highly modded street one? thats what makes the difference..and thats why everyone here would get away with it..
Old Jul 16, 2008 | 12:27 PM
411Z's Avatar
411Z
this is true. but thats not to say that it couldnt happen... especially in drag racing. do you have any idea the amount of strain exerted on parts in this sport? even on a stock cadillac you could break things.
Old Jul 18, 2008 | 06:17 AM
SnyperZ's Avatar
SnyperZ
very true..but theres no sense comparing something that happend to a car with 10x the torque as an example of why not to do it. On a car like that its an absolute must..on ours its more of a preference thing.
Old Jul 18, 2008 | 07:37 PM
_350Lee_'s Avatar
_350Lee_
whats the best way to do it. it almost looks like you have to take of the exahust manifold to get to the top bolt, because of the angle its at.
Old Jul 19, 2008 | 07:31 AM
MardiGrasMax's Avatar
MardiGrasMax
The pan will hold the engine if you spread the weight with with a piece of 2x6, I've done it many times.
Old Jul 19, 2008 | 02:09 PM
FAIRLADYZ_MANnE's Avatar
FAIRLADYZ_MANnE
Question is, will a solid tranny mount help in shifting smoothness, because everyone knows how shifty our trannys can be.
Old Jul 24, 2008 | 06:14 PM
Eazzy's Avatar
Eazzy
Full coverage support by the pan is fine so long as you use a 2x6 or so of a slightly larger dimension than the pan
