Oil Pressure sending unit
Old Jul 23, 2008 | 07:33 AM
StandardIdiot's Avatar
StandardIdiot
Default Oil Pressure sending unit
Im having a little trouble finding an oil pressure adapter for my z. I have a sending unit with 1/8 npt thread and i would like to buy a t adapter to add it.
these are the only adapters i could find. I have an additional oil sandwich plate that I added for my oil cooler but it does not have extra ports since they are bing used.
This is what I have found but I do not know what the thread size for my oil pressure port is.
http://www.nissport.com/catalog/prod...ctCode=NS-2100
What did you guys do with your oil pressure sending unit?
Old Jul 23, 2008 | 07:39 AM
str8dum1's Avatar
str8dum1
you want NS-2100U
its british pipe thread standard.
Old Jul 23, 2008 | 07:43 AM
StandardIdiot
Thank you very much.
Old Jul 23, 2008 | 05:18 PM
rcdash's Avatar
rcdash
The stock oil pressure sender is BSP? Not NPT? I'm pretty sure I took it out of an NPT T that ForgedPerformance put it into to get an aftermarket sensor on there. I put it back into the JWT T for the split to the turbos. I thought it was NPT. I could've sworn it tightened like an NPT fitting...
Old Jul 26, 2008 | 04:05 PM
StandardIdiot
Anyone else have input on this, I just want to make sure before I order it.
Old Jul 31, 2008 | 03:40 PM
rrmedicx's Avatar
rrmedicx
I believe its a 1/8 BSP. Quad cam just did an oil pan mod and added a second and third 1/8 BSP port to accommodate oil feed lines for his TT set-up.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
