3.9 and 4.08 shims
Old Jul 23, 2008 | 09:36 PM
krivera6950's Avatar
krivera6950
Default 3.9 and 4.08 shims
where can i buy the correct size shims for the install?
Old Jul 23, 2008 | 11:09 PM
kramykram's Avatar
kramykram
you can't buy the correct shims unless you have the tools needed to tell you what shims sizes you will need. but if you just want to order shims.
www.courtesyparts.com
Old Jul 24, 2008 | 08:33 AM
jbudnick504's Avatar
jbudnick504
Do these really work?
Old Jul 24, 2008 | 08:36 AM
Kwame's Avatar
Kwame
Does what really work? The shims or the gears?
If you are asking about the gears, yes they do, and the shims may or may not be necessary for the installation of the gears.
Old Jul 24, 2008 | 05:58 PM
Eazzy's Avatar
Eazzy
Every ring and every pinion is different, as is every Gear Case whether it is of the same ratio or not---hence, each build has to be shimmed independently to achieve the specified specs for that unit.....Side gear clearance, pre-load torque, backlash etc.
Sunset350ZR
Nov 15, 2015 05:45 AM
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
emooheo
Oct 14, 2015 08:58 AM
1973camarolt
Drivetrain
Oct 11, 2015 01:26 PM
Bodyboarder81
Sep 21, 2015 06:23 AM
