how to adjust idle?????
Old Jul 24, 2008 | 08:56 PM
tylerxfire's Avatar
tylerxfire
Default how to adjust idle?????
hey guys new to the z just seeing how i would go about adjusting the idle up a little, due to my noisy flywheel, thanks
Old Jul 24, 2008 | 08:57 PM
mikez97's Avatar
mikez97
re-flash your ecu.
Old Jul 25, 2008 | 08:26 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
get a cipher
Old Jul 25, 2008 | 08:37 AM
blaukal's Avatar
blaukal
to add to the above, it has to be done through the ECU-- dealer will do it for you -- no DIY mechanical adjustment
Old Jul 25, 2008 | 08:39 AM
Nexx's Avatar
Nexx
upping your idle isnt going to help your flywheel chatter much if at all.
Old Jul 25, 2008 | 09:43 AM
Vas@Extended's Avatar
Vas@Extended
Vendor - Former Vendor
yuppp
Old Jul 25, 2008 | 09:52 AM
DavesZ#3's Avatar
DavesZ#3
The idle can only be bumped on the '03/04 models through Consult. The 04.5+ ECUs are ULEV which doesn't allow for idle adjustment.
Old Jul 25, 2008 | 10:47 PM
OCG35's Avatar
OCG35
Osiris...
Old Jul 28, 2008 | 10:23 AM
tylerxfire's Avatar
tylerxfire
its worth a try others have had luck with it, i just want to get rid of the little chatter while its sitting there idling at low rpm's, so anyway i have a 03 you are saying just go to the dealer and they can do it right there, but on the topinc of reflashes, any advice on this, i have injen intake and nismo cat back on the way, along with clutch and flywheel and etc. but who should i go through for a tune, i live in upstate ny and there are not really any dyno tuners around here that i could go inhouse, anybody around me?? or should i just send it out somewhere. thanks
liqalu04
Jan 2, 2022 12:58 PM
Darkspy
Sep 7, 2015 09:09 PM
