Calling all 6mt Rev-Up Engine Owners..
Old Jul 30, 2008 | 07:04 PM
  #41
PDX_Racer's Avatar
PDX_Racer
Originally Posted by ArCtM
Does that have the rev up?
'05 Track and 35AE MT were the first.
Old Jul 30, 2008 | 07:15 PM
  #42
__jb's Avatar
__jb
Z + Rear Seat
Originally Posted by bimmertech
it is very upsetting. i do not think the rings are the problem. i personally feel they did not build the engine to turn 7k rpm on a regular basis--specifically the rod ratio. almost all VQ's burn a bit of oil, but the increased rpm really magnified the problem. i also suspect this due to the 07's not having any issues at all and having a taller deck with longer rods. i'm not engineer, but it makes sense to me.
Interesting.
The VQ37HR in the G has a taller deck and a longer stroke. I wonder if the stroke to rod ratio in the VQ37HR is the same as the VQ35HR?
Old Jul 30, 2008 | 07:49 PM
  #43
dmroberson's Avatar
dmroberson
Oh, throwing this out there... met a guy the other night with a new G37 Coupe, and he's losing a little more than 1 quart every 1000 miles already... I think he said he's got about 5K on the clock...
Old Jul 31, 2008 | 12:50 AM
  #44
Shift__Z's Avatar
Shift__Z
nissans are known for oil consumption just ask my 04 spec v
Old Jul 31, 2008 | 01:25 AM
  #45
meow69's Avatar
meow69
no problems on mine
Old Jul 31, 2008 | 03:18 AM
  #46
Nismo1182's Avatar
Nismo1182
Yup those 2.5's are the worst lol
Old Jul 31, 2008 | 07:02 AM
  #47
gothchick's Avatar
gothchick
No ****? Ouch... Hopefully it's just part of the breakin for that motor.
When I was breaking mine in, it was consuming about 1qt per 4k mines, now at 24k miles on the clock, it's inceased to 1qt per 3k miles. Slowly getting worse...
I'm thinking it's gotta be a "wear" item like rings, valve seal guides, seats, etc...
Old Jul 31, 2008 | 07:06 AM
  #48
Blwn_By_Twins's Avatar
Blwn_By_Twins
Use it as a bargaining chip and get a better deal.
Old Jul 31, 2008 | 08:21 AM
  #49
drive4fun's Avatar
drive4fun
I wonder if it's too early to determine whether or not the VQ35HR engines are going to have the oil consumption issue. This engine comes in the 2007-2008 350z, and the 2007 G35 Sedan. The new G37 is also questionable.
Seems like Nissan/Infiniti are infamous with oil consumption issues.
I really wanted a G35 since day one. I can't believe the engine was awarded top 10 engines for all those years. They must have tested the automatic only.
Thanks for everyones input. Keep the suggestions and feedback coming.
Old Jul 31, 2008 | 05:28 PM
  #50
bimmertech's Avatar
bimmertech
Originally Posted by __jb
Interesting.
i thought the deck height in the 35hr/37hr/40 were all the same
Old Jul 31, 2008 | 06:57 PM
  #51
ZPHILE's Avatar
ZPHILE
Default Haven't noticed anyone on the '06 Oil consumpt'n page here...
I had a '06 MT ZR with 3 different engines. Had enough - did a buyback and got a '08 MT ZR 900 below invoice. I would'nt waste my time on a '06 MT if I had to do it all over again. There's fantastic deals on '07's and others if you do your homework. Make sure you read this thread:
https://my350z.com/forum/engine-driv...iscussion.html
Old Jul 31, 2008 | 07:03 PM
  #52
PDX_Racer's Avatar
PDX_Racer
Strange, my 2002 never had oil consumption problems.
But then again, I've had both on autocross courses before 1000 miles (the SpecV had 600 miles, and the Z had less than 300 miles -- but it was wet)
Old Aug 1, 2008 | 12:54 PM
  #53
__jb's Avatar
__jb
Z + Rear Seat
I would assume the deck height to be different on the VQ35HR and the VQ37HR because of the stroke difference.
Nissan could move the wrist pin in the piston and keep the rod length the same. I was just thinking they'd try to keep the pistons the same.
Old Aug 1, 2008 | 07:29 PM
  #54
bimmertech's Avatar
bimmertech
from what i understand the 37hr is a small bore 40 pretty much. which would be a stroked 35hr.
they could move the wrist pin, but that might permit more oil consumption. i would imagine that they used the 40 crank/rods, but used a diff piston all together.
i am prolly wrong though and have 0 technical information to back this up.
Old Aug 2, 2008 | 05:00 AM
  #55
Shift__Z's Avatar
Shift__Z
No the 02s didnt have oil consumption issues they had tranny and cat issues . The 04s are the ones that had cat and oil consumption issues
Old Aug 2, 2008 | 11:37 AM
  #56
PDX_Racer's Avatar
PDX_Racer
Don't forget about the butterfly screws.
OTOH, there are still times that I miss my old SpecV.
Old Aug 2, 2008 | 09:29 PM
  #57
Shift__Z's Avatar
Shift__Z
ya me too cuz it was FastAr...
Ya you know you own a spec v when your afraid of cats and butterflies
Old Aug 4, 2008 | 12:30 PM
  #58
MikeyG's Avatar
MikeyG
why?
Because it was a hastle to have the engine replaced. Now I am real hesitant about doing any mods to the engine in case it happens again as it has to quite a few people and have a hard time getting it replaced under warranty. Would rather not have a model year with this problem.
Old Aug 14, 2008 | 05:30 PM
  #59
drive4fun's Avatar
drive4fun
Yeah, I would be hesitant modifying a rev-up G35/350z. I would most likely keep it stock for a while until I can get a read of the oil consumption pattern.
Old Aug 14, 2008 | 08:23 PM
  #60
PDX_Racer's Avatar
PDX_Racer
Kittens (pre-cats) and butterflies.
It was such a sleeper!
