Custom Oil Cooler Installed
Old Jul 29, 2008 | 11:58 AM
Crom's Avatar
Crom
Default Custom Oil Cooler Installed
Just got back from Corner 3 garage where my friend's steve and nima did a amazing job on a oil cooler install that I've been piecing together for quite some time. Basically I went w/ a setrab 19 row w/ the proper An- fittings and earls tubing plumbed into the Mocal thermostatic adapter w/ the greddy sandwich adapter being used in conjunction to accomodate the oil pressure and temp sensors wired into the defi-link setup. Both of these together provide a good amount of clearance of the APS oil pan for a easier install as well. Then a custom air channel was fabbed to direct flow into the cooler that sinks up perfectly to my Chargespeed type-2 bumper. you can't even see the cooler from the front at all, very clean IMO. Then a pretty beefy bracket was fabbed to firmly keep the oil-c in place. A additional PS cooler was added that is essentially wired into the existing PS-cooler and mounted directly below the intercooler. The thickness of the metal of the APS intercooler is very thin so additional material was welded onto the bottom so this can be attached securely. At last the methanol injection pump was relocated and then....DONE. Finished pics to follow. Also a quick thanks to Cheston for answering some lame questions I had.
Old Jul 29, 2008 | 12:00 PM
iStan's Avatar
iStan
ZR
I like it. Mine is higher though because of the Stock bumper. Currently using the stock Corner Reflector holes for ventilation. Added a bunch of cuts/vents to the fender liner as well so the air had somewhere to go.
Old Jul 29, 2008 | 12:02 PM
Crom's Avatar
Crom
^ Sweet....
Old Jul 29, 2008 | 12:09 PM
QuadCam's Avatar
QuadCam
nice work.....I love seeing custom work.
Old Jul 29, 2008 | 04:43 PM
R-TuneZ's Avatar
R-TuneZ
hmmm....
only thing i dont like is the fact that your filter element is right next to the cooler. i like the air diversion mod they threw on there for you, i have put something similar on mine in order to aid in lowering the intake charge.
Old Jul 29, 2008 | 05:35 PM
Crom's Avatar
Crom
^..yea its actually not that close...the depth of the straight-on shot is a little misleading. but everything together is def a glove-like fit.
Old Jul 29, 2008 | 05:51 PM
R-TuneZ's Avatar
R-TuneZ
word, i can understand that, i figured that was prob the case. either way it looks great, congrats .
so you stacked the mocal and greddy adapters? any issues with that? is the filter on the stock location or remote? also, what is defi-link? i am not familiar with the term.
Old Jul 29, 2008 | 05:57 PM
Crom's Avatar
Crom
Yea...its in the stock location..no issues- it actually works out nice. This setup helps clear the APS oil pan and gives you the necc gauge attachments. the link unit is just what the sensors coming off the adapter plugs into for oil temp and press.
Old Jul 30, 2008 | 06:04 AM
gothchick's Avatar
gothchick
Very nice. Love to see well fabbed mods~ :-)
Old Aug 3, 2008 | 09:59 PM
Crom's Avatar
Crom
Everything back together....
Old Aug 4, 2008 | 10:59 AM
Crom's Avatar
Crom
So far temps have been great - slow moving traffic or aggressive street driving I see temps at 215-220, I jump on the freeway and they drop to 200-205.
Old Aug 4, 2008 | 02:40 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Very nice work.
Old Aug 4, 2008 | 03:27 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
what were your non oil cooler numbers? i hit 240 crusing on the interstate.
whats with the intake pipe getting squashed as it goes through the rad support?
Istan, what kit do you have? thats an odd location for a vortech bpv. looks custom.
Old Aug 4, 2008 | 03:34 PM
Crom's Avatar
Crom
Didn't have the oil sensor before now...Intake pipe squashed ?
Old Aug 4, 2008 | 03:36 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
sry, first pic. Looks like it but upon reinspection..........shadows playing games.
Old Aug 4, 2008 | 06:05 PM
Crom's Avatar
Crom
If anyone is in the area, I highly recommend these guys, I've been goin here for the past couple of years and couldn't recommend a better shop . Lots of custom fabrications, and applications to get the most out of your mods.
Old Aug 4, 2008 | 06:10 PM
carfi179's Avatar
carfi179
Nice work Joe...oil cooler will be my next mod. Do they tune as well at this shop?
Old Aug 4, 2008 | 06:24 PM
Crom's Avatar
Crom
Nah, no tuning...but they install and/or troubleshoot just about anything. I think their having a barbecue coming up pretty soon, you should roll down.
Old Aug 4, 2008 | 08:44 PM
carfi179's Avatar
carfi179
Sounds good, let me know when their hosting a bbq.
apex locator
Jul 23, 2021 02:27 AM
