Stillen Supercharged
Old Aug 1, 2003 | 01:38 PM
Chebosto's Avatar
Chebosto
if you think about it.. it makes perfectly good sense..
the ATI sits forward of the intake, the Stillen one sits ontop of the intake manifolds..
route the belt from the manifold to the centrifugal blower and you'd have some crazy power! wee!
Old Aug 1, 2003 | 01:46 PM
elektrik_juggernaut's Avatar
elektrik_juggernaut
and your engine would cook eggs better than the George Foreman Grill
Old Aug 1, 2003 | 01:48 PM
Del350's Avatar
Del350
Originally posted by elektrik_juggernaut
or maybe they could use your ECM and get 7 more horsepower out of it
Old Aug 1, 2003 | 02:04 PM
Chebosto's Avatar
Chebosto
Yup. and my engine would be running efficiently and correctly with a tuned george foreman grill and boost
Old Aug 1, 2003 | 02:43 PM
teh215's Avatar
teh215
Couldn't we use a twin turbo kit to pressurize the ATI blower which would pressurize the Stillen blower. That should be enough to pop the heads off of the motor, but the sound it make for the 3 seconds of the motors life would be incredible.
Old Aug 1, 2003 | 03:44 PM
spazpilot's Avatar
spazpilot
first of all skk100 good luck on the stillen supercharger. it puts out 309rwhp at 5.6psi which is not bad. if anybody wants to watch the video goto http://www.350zforum.com/. its at the top were it has a high and low res. i also heard stillen is planning on making a water to air intercooler which will sandwich between the intake and blower. you will not have to moddify the hood anymore it was already worked in from the beganning. there also going to add different pulley for boost up 10 psi. that in theory whould make it a 400rwhp monster. only catch is for 10psi on a 10.3 compression means you would have to buy something like stillen off road headers to remove the cats to run that safely
cheston : still waiting to see what you will do with pe turbo or its greddy for me. hope all works out for you
Old Aug 1, 2003 | 03:50 PM
spazpilot's Avatar
spazpilot
i also forgot if were going to use th turbo to power the ati in turn power the stillen and the updated ecu to cook it right we should go ahead and add some NOS
Old Aug 1, 2003 | 06:04 PM
at350zguyy's Avatar
at350zguyy
right now my car is all stock but next week im getting the nismo cold air intake.
here are the rest of the mods i plan to do:
-ECU chip
-borla exhaust
-underdrive pulley
-headers
-procharger kit
so by the time im done itll have about 500 horses
Old Aug 1, 2003 | 08:51 PM
skk100's Avatar
skk100
Well I picked up my Z today. It feels awesome with the Stillen supercharger. I drove it in LA traffic for 2 hours and the temperature gauge didnt budget from stock. I love the whine when I slam the throttle. My only question to Stillen on Monday is I hear a slight ping at low speeds. Does anyone know anything about the engine pinging at low speeds at full throttle? I will take some pictures tomorrow and post them.
Old Aug 1, 2003 | 08:53 PM
ravaz's Avatar
ravaz
Did they dyno your car? If so, what were the result?
Old Aug 1, 2003 | 10:14 PM
Jumpman--Z's Avatar
Jumpman--Z
Can the Stillen supercharger and the ATI Procharger pass smog?
Old Aug 1, 2003 | 11:40 PM
elektrik_juggernaut
Both are pending CARB certification.......ATI has many, many other supercharger kits for lots of different cars.........the street versions have all received CARB certs.......i dunno how far off Stillen's cert is
Old Aug 2, 2003 | 07:46 PM
Thanos's Avatar
Thanos
Default Post Pics?
Can you post some photos of all of your mods? I am very curious to see how your Z looks and performs.
T
Originally posted by skk100
Well I hope all turns out well. I had an M3, and a 540i and loved both those cars. Stillen is luckily only an hour away and if all doesnt turn out well I will be throwing this supercharger through their office window.
Old Aug 6, 2003 | 09:00 AM
elektrik_juggernaut
The pinging you hear might be detonation.......i would tell them about this........detonation is fuel igniting earlier than it's supposed to.......it's a bad thing
An intercooler could help this.......but i think Stillen is only offering the intercooler for off-road applications
Old Aug 6, 2003 | 09:16 AM
ForceInduction's Avatar
ForceInduction
The pinging most likely is detonation. This can be from lack of fuel or to much heat. You may want to run some colder spark plugs. If you get the Denso's Iridium's they are pre gapped. If you don't get the Denso's, stay away from the Platinums and gap them around .032-.035. This might do the trick for you. But, you need to take care of this as soon as possible, because detonation is very bad. Make sure you go one heat range colder...I think this might do the trick.
Old Aug 6, 2003 | 01:52 PM
skk100's Avatar
skk100
The sparkplugs were changed to the ones Stillen suggested. I have a call into Stillen but no response yet. Does anyone know the downside of adding an octane booster to each tank of gas? Could this potentially stop the pinging?
Old Aug 6, 2003 | 03:50 PM
Traffic's Avatar
Traffic
You gotta make a video if you do that
Old Aug 6, 2003 | 04:33 PM
  #38
ForceInduction
The octane booster may work, try it. But, it will only temporary solve the problem. You may also turn down your timing, that will help you out or even eliminate the knocking. What are your plugs gapped at?
Old Aug 6, 2003 | 06:09 PM
  #39
little_rod's Avatar
little_rod
Yeah, octane booster could help, but make sure you don't waste your money on the store bought ones. Buy some toluene or xylene, they are what is really inside those store bought boosters. Toluene is like 114 octane and xylene is like 117 octane.
Old Aug 7, 2003 | 05:51 PM
  #40
Edretti's Avatar
Edretti
Where are the pics mannnn!!!
