Exedy VS ACT clutch?!?!
Old Aug 18, 2008 | 11:52 AM
VTMustard's Avatar
VTMustard
Default Exedy VS ACT clutch Question?!?!
I am looking to upgrade my clutch and flywheel setup! I have pretty much made up my mind that I am getting the ACT Prolite Flywheel, but I have a choice to make when it comes to the clutch to mate with it. My first choice, is the Exedy Stage 2 clutch. Since I am NA with bolt-ons, the 342 ft/lbs torque rating is probably ideal, but I dont know if it mates well with the ACT prolite, in addition I haven't really seen many reviews about this clutch, there seems to be plenty of reviews for the stage 1 and JWT setups, but noone seems to have stage 2. My second option is the ACT HDG6 6-Puck Sprung clutch, this seems like a great clutch and I know it will mate well with the flywheel, my only concern is whether it is overkill for the current state my car. I am kinda curious what the communities opinion is with these two clutches and how they work with the ACT prolite! Thanks
Old Aug 18, 2008 | 07:01 PM
thawk408's Avatar
thawk408
I LOVE my ACT clutch. I have the 6 puck sprung with the streetlite flywheel and its really not bad to drive. It also holds 19 psi like a champ!
Old Aug 19, 2008 | 09:43 AM
shane23fisher's Avatar
shane23fisher
I Talked To The Guy @ Gruppe-s ; He Said The Prolite Is Too Overkill On The Transmission........ First My Pops, Who Has No Status.... Then The Guy @ Grouppe-s
Old Aug 19, 2008 | 10:04 AM
RedBullRR's Avatar
RedBullRR
I have the ACT Streelite with Exedy Stage 1 clutch, love it! Flywheel can get a lil noisy after beating on it for a while. Also upgrade your clutch line to stainless steel.
Old Aug 21, 2008 | 05:36 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
not sure what "overkill for the transmission" means. It's still quite easy to drive, just makes a touch more noise than the streetlight. However, it also is lighter, and revs a bit quicker. I've used both, and either one is a great choice
As far as the clutch, the Exedy or ACT std HDSS would work perfectly well - ACT holds considerably more torque, but is more expensive than the Exedy.
An Exedy + ACT flywheel would make a very nice, more than capable, economical setup
Old Sep 1, 2008 | 01:39 AM
ppun88's Avatar
ppun88
Default Clutch Q??
I just got the same setup as you do but i hear a lot of chatter between 1k and 2k RPM... is this normal? I coudnt find another thread about ACT flywheel with exedy clutch.
Old Sep 2, 2008 | 05:46 AM
Z1 Performance
Former Sponsor
every flywheel on the market makes noise at low revs...it is normal
Old Sep 3, 2008 | 08:41 PM
shane23fisher
I got the OEM Exedy and Streetlight... the idle is screwed up.... common or what?
Old Sep 4, 2008 | 04:28 AM
Z1 Performance
Former Sponsor
what does "idle is screwed up" mean?
Old Sep 6, 2008 | 11:18 PM
woogie12's Avatar
woogie12
Higher revving idle? Bumpy idle? No se. Do tell.
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
