Shorter Tire+rim = Shorter Final Drive = Faster?
Old Jul 31, 2003 | 09:48 AM
OCG35Coupe's Avatar
OCG35Coupe
Default Shorter Tire+rim = Shorter Final Drive = Faster?
Thought you guys might like this calculator. I gotta get back to work lates.!
Effective & Equivelant Gear Ratio Calculator
I would try and fill in some question but gotta run.
Old Jul 31, 2003 | 10:32 AM
Juztin's Avatar
Juztin
I'm gonna be running 20" rims in the back, so my ratio is gonna suffer a tad with acceleration. I've been trying to dig some nfo on R200 gear swaps. Looks like nismo has a 4.444 and even a 5.12 gear upgrade for the R200 floating around, older Z's not 2003 so I'm worried if the R200 has been majorily modified, or hopefully I can swap. right now with the 3.5 gear, I would like to atleast step up to a 4.12 or so, but 4.444 would be awsome. Hey Jeff @ Courtesy Nissan, if you read this, do you know if you can get those gear upgrades from Nismo for the R200??? For the R200 and not the R200V that is, I have a base model with no LSD. Thanks for the link 2 the app, definately useful
Old Jul 31, 2003 | 10:39 AM
2003z's Avatar
2003z
the 90-96 non turbo Z uses a 4.06 rear end R200V
Old Jul 31, 2003 | 05:47 PM
PhoenixINX's Avatar
PhoenixINX
We ran the calculations on this...
Going from our 3.5 to a 4.10 will net you faster times in the 100 ft, and 600ft... but in the 1.4 mile you will have the SAME time and actually have lower trap speeds.
More so, if you were to go FI... you'd be having to shift like its a motorcycle.
NO THANKS.
Old Jul 31, 2003 | 06:13 PM
2003z's Avatar
2003z
thanks for the info! can cross that one off the list! (although I really thought I was the first to think of this, now how about a 350Z diff in a 240Z, hmmmm???)
Obadabot
Jun 18, 2023 11:31 PM
3vilbunny
Jul 18, 2017 05:10 PM
samansharif
Sep 25, 2015 12:31 PM
