High Oil Pressure?
Old Aug 25, 2008 | 03:23 AM
Rudiger's Avatar
Rudiger
Question High Oil Pressure?
Hi !!
I have a 07'SMB, and before it, I had a 06'MB.
I have noticed that the normal oil pressure (in all situations) is a little higher in the '07 than in the '06 (with a 0W30 factory oil).
I have changed the oil for the first time last week (Mobil 1 5W50) and I have noticed that the oil pressure is even higher, which is reasonable in priciple as the oil viscosity is higher too. But I think it's too high, what do you think about it?
* Oil pressure at engine starting (cold engine - 15 ēC Exterior temperature): 110 psi.
* Oil pressure at operating temperature @2500 rpm: 80-90 psi.
* Oil pressure at operating temperature @idle: 30 psi.
* Oil pressure at operating temperature @full speed up: 115-120 psi.
Thanks in advance !!
Old Aug 25, 2008 | 03:27 AM
Rudiger's Avatar
Rudiger
That is, 60 ēF Exterior temperature...
Old Aug 25, 2008 | 03:40 AM
Z04's Avatar
Z04
please read your owner's manual
Old Aug 25, 2008 | 03:50 AM
Rudiger's Avatar
Rudiger
TFM only says that "When the engine speed is high, the engine oil pressure is also high. When it is low, the gauge indicates the low oil pressure."
I was only asking because I noticed that the oil pressure was higher at the '07 in respect of the '06 at the same operating conditions with the same oil, and I don´t know if driving constantly over 90 psi is good at all for the engine, and in fact over 150 psi at sport driving...
Old Aug 25, 2008 | 03:51 AM
Rudiger's Avatar
Rudiger
... and in fact over 150 psi at sport driving...
Sorry, I can't edit my messages... I meant 115 psi ...
Old Aug 25, 2008 | 07:21 AM
Z04's Avatar
Z04
that is because the 2007 is a HR engine, where the 2006 is a DE engine. though the VQ35 is the same, they are completely different. you can not compare an apple to an orange and expect the same result
Old Aug 25, 2008 | 07:29 AM
WhiteNoiz's Avatar
WhiteNoiz
^^what he said, and make sure you didnt put too much oil in it.
Old Aug 25, 2008 | 11:15 AM
alfonsohaskins's Avatar
alfonsohaskins
what if u put too much in, cause i went over a little bit and now my engine makes this smell of buring oil. what should i do? although the smell has gone down a bit, and oil is back within normal ranges. i can still smell it, what should i do? iam out of the country and it's a little hard to get stuff done on it. and there is not any nissan dealerships around
Old Aug 25, 2008 | 12:54 PM
Z04's Avatar
Z04
mathews nissan is right up the road near exit 11, but i take it you are overseas after seeing some of your other posts so i know that does you no good. but as for that smell, you probably got a bit on the block itself and that smell is the oil burning off. if your level is normal then you got nothing to worry about.
Old Aug 25, 2008 | 01:28 PM
Rudiger's Avatar
Rudiger
Ok, I understand that, but... then, you don't think those values for oil pressure are too high, do you?
Sorry for my insistence, but I'm a little concerned with this issue.
Old Aug 26, 2008 | 01:49 AM
Z04's Avatar
Z04
not at all, those look normal to me
Old Aug 26, 2008 | 06:49 AM
alfonsohaskins
thanks for the help and i hate mathews nissan they tried to screw me a couple of times it is where i bought my z from
Old Aug 27, 2008 | 12:37 AM
Rudiger's Avatar
Rudiger
Wink
Thanks !!
apex locator
Jul 23, 2021 02:27 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
