5th gear frustration! Can you answer my question?
Old Sep 16, 2008 | 05:53 PM
Adamtwelve's Avatar
Adamtwelve
Default 5th gear frustration! Can you answer my question?
I have an '03 350z, with about 40,000 miles. A while after I bought the car I noticed that when I shifted to 5th gear there was a bit of resistance, no grinding, other gears shift fine. Now 5th gear is locking out! It only goes into 5th gear when I push down on the shift like I was going to put in in reverse. Could it have something to do with the reverse saftey lockout??? I also noticed that my shifter feels long and loose, or flimsy, rattles sometimes! A friend of mine owns a 350z and his shifter is not as loose as mine!....Any ideas????
Old Sep 16, 2008 | 06:21 PM
INTIMAZY's Avatar
INTIMAZY
Theres a "guide" plate below the shifter that tends to get misaligned causing either a common 1st or 5th gear issue that you described. That might just be it.
Old Sep 16, 2008 | 06:22 PM
henry j's Avatar
henry j
do you have warranty? if so take it to the stealership
Old Sep 16, 2008 | 06:30 PM
Adamtwelve's Avatar
Adamtwelve
No warranty! But I will have to check out that guidance plate, the shift can actually stretch past the 5th gear slot by about an inch or so, into no mans land!.....Thanks for ur help!!
Old Sep 18, 2008 | 11:56 AM
mavtais's Avatar
mavtais
On the shifter shaft, there is a flange that bumps against the guide plate below. You either have the flange worn out, or the guide is mis-aligned. Take off the boot cover and you can see the reverse lock-out feature is extremely simple. My buddy's 03 track ed. has the same issue.
Old Sep 18, 2008 | 12:23 PM
ADMAN's Avatar
ADMAN
Old Sep 18, 2008 | 02:53 PM
Adamtwelve's Avatar
Adamtwelve
Ok, Im hoping that its just the guide and not the flange being warn!....I will see tommorrow when I check it out!....I will let ya know! Thanks!!!
Old Sep 22, 2008 | 01:20 PM
Adamtwelve's Avatar
Adamtwelve
Problem solved!......was just the guide plate!.....THX 4 your help guys!!!
sherm
Apr 11, 2020 05:21 PM
Depravity
Oct 1, 2015 04:49 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
