Time to replace clutch/fly???help..
Old Oct 21, 2008 | 05:43 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Question Time to replace clutch/fly???help..
Starting today, my car has been acting weird...you can hear it in the video. it started making rattling/breaking sound under the car. I'm assuming that it's coming from the clutch/flywheels.
- when car is stopped, i can hear it a little bit
- when i put it in first gear, and let the clutch go slowly, i don't hear it very loud. ( without pushin accelerator )
- when i let my clutch go and push the accelerator, it starts making a loud noise...
please help guys....is it time to replace my clutch/flywheels? or something else?
* Uploading video *
Edit: somehow i can not upload the video here, so here is link!!!
http://vids.myspace.com/index.cfm?fu...deoid=45051683
Old Oct 21, 2008 | 06:22 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
throw out bearing....common issue, but its only going to get worse and you run the risk of damaging the bearing altogether (not good!)
you can change just the bearing, transmission has to come out though - good time to upgrade the clutch and flywheel though if your budget allows for it
Old Oct 21, 2008 | 06:37 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
^ thanks adam. will it be ok for driving couple weeks? my car will be in storage for over the winter...
Old Oct 21, 2008 | 06:41 PM
Z1 Performance
Former Sponsor
actually just re-read your description
with the car running, does the noise change when you push the clutch pedal in vs let it out (car does not have to be in gear, just running)?
Old Oct 21, 2008 | 06:48 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
even not in gear, i hear very little bit, i couldn't even catch from camera. But when it is in gear and press gas, ( when i let the clutch slowly) it gets really loud...But i can pretty much tell it's from clutch/flywheel..because i drove it really hard after installed the exhaust system..( damm ur HFC )
Old Oct 21, 2008 | 06:57 PM
Z1 Performance
Former Sponsor
k - more than likely the throw out bearing then
Old Oct 21, 2008 | 07:04 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
^ Thanks for clear answer adam, i guess it will be my next project to be done, will touch you soon for drivetrain
Old Oct 22, 2008 | 09:39 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
One more question, if not replace throw out bearing and just driving for 2~3 weeks. what worst scenario can happen? I don't know, if it will be ok to do after winter.
As request PM:
Just tapping gas pedal ( without clutch in) it making a noise under 1500k rpms also.
Old Oct 22, 2008 | 10:50 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Bump for info
Old Nov 7, 2008 | 09:09 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Update: Found out my pilot blushing was broke.
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
SharX59
Sep 27, 2015 09:23 AM
samansharif
Sep 25, 2015 12:31 PM
