clicking noise from engine
Old Oct 22, 2008 | 02:45 PM
frankie's Avatar
frankie
Default clicking noise from engine
My engine sounds like its making a clicking noise when its parked and when its in gear it just started today after work. What could be the problem with my car.
Old Oct 22, 2008 | 02:54 PM
frankie's Avatar
frankie
its more like a rattling with something lose but everything is tight it sound to be coming from the intake manifold and cover
Old Oct 22, 2008 | 03:07 PM
j1234's Avatar
j1234
are u using a nissan oil filter?
Old Oct 22, 2008 | 03:41 PM
frankie's Avatar
frankie
i am using a fram oil filter
Old Oct 23, 2008 | 04:27 AM
blue350zed's Avatar
blue350zed
I never noticed it before until last night when my wife was getting out of the car and I was still in gear. Once I put it in neutral and got out to check it out, it stopped. I'll let you know if I find out anything, but I'm still looking also.
Old Oct 23, 2008 | 04:44 AM
lanceccs's Avatar
lanceccs
I noticed the clicking sound from my 03 as well..donno if something is wrong. Pls keep us updated if u find the root cause.
Old Oct 23, 2008 | 07:33 AM
atomicgoofball's Avatar
atomicgoofball
get ur oil changed, when was the last time u did that?
Old Oct 24, 2008 | 01:23 PM
j1234's Avatar
j1234
the reason your engine is clicking is because you are not using a nissan oil filter or equivalent. the nissan oil filter has a special valve called an anti-drain back valve that prevents oil from draining back into the crank case during a shutdown. what happens is if you use a filter other than nissan or K&N which has the anti drain back valve, the rockers for the valve train become un primed and start making a clicking noise. this is why you hear the noise coming from the plenum. just start using either K&N or nissan oil filter next oil change and after a while it should go away. it should not harm your motor in the mean time. i have the same noise with my engine and the nissan techs told me its a very common complaint people come in with in the VQs.
Old Oct 24, 2008 | 01:24 PM
j1234's Avatar
j1234
yours sounds more like normal clutch chatter
Old Oct 24, 2008 | 01:50 PM
cracka350z's Avatar
cracka350z
there is a nigerian scammer in there trying to sell you something!!!
Obadabot
Jun 18, 2023 11:31 PM
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
