MODS and Emission testing
Old Aug 18, 2003 | 05:39 PM
nigevellie's Avatar
nigevellie
Default MODS and Emission testing
which mods can be done and still let you pass an emissions test? i am in houston, so all the TX Z owners out there, please help. thanks.
Old Aug 18, 2003 | 06:21 PM
Sillent Killer's Avatar
Sillent Killer
Well...
Grounding Kit
Intake
Intake Plenum
Headers
Y-Pipe
Clutch
Flywheel
Pullies
ect...
Pretty much anything except test pipes.
Old Aug 18, 2003 | 06:35 PM
Strom's Avatar
Strom
Pretty much anything that doesn't affect the OBDII system should be fine. They don't actually test what's coming out of the tailpipe(s) - unlike states such as California or Colorado. That means that, as long as all of the OBDII components are in place, you pass.
Old Aug 18, 2003 | 06:38 PM
nigevellie's Avatar
nigevellie
thanks for the reply. so it's open season except for test pipes, eh? what about you guys with test pipes? are you worried about emissions testing at all? also, which mods hurt the _street_ drivability of the z? i believe the z is a very easy and forgiving car to drive. it's my daily driver and i would hate it if mods make it hard to drive to z. thanks again.
Old Aug 18, 2003 | 06:41 PM
KONVERTER's Avatar
KONVERTER
headers wont pass visual inspection...
your intake must be carb approved.. i believe the aem is... im not sure though...
Old Aug 18, 2003 | 07:54 PM
Strom's Avatar
Strom
If he's in Texas, CARB doesn't matter. They basically just connect your vehicle to an OBDII reader and make sure all the OEM emissions equipment is there.
Old Aug 19, 2003 | 12:12 PM
myinfinitig20's Avatar
myinfinitig20
****ing california
Old Aug 19, 2003 | 12:35 PM
cbsuper's Avatar
cbsuper
Good ol AZ, I don't have to worry about emissions until my car is three years old.
Old Aug 19, 2003 | 12:45 PM
John's Avatar
John
Thumbs down
In Northern Virginia, they measure the tailpipe emissions...
Old Aug 19, 2003 | 02:10 PM
bought's Avatar
bought
You might get lucky and pass the headers inspection on your Z's as its a bit tight (space-wise) so they might not see them. I can barely seem mine on my G coupe. In any case, I hope I pass emissions as I live in California. Anyone know the consequences of not passing emissions? I understand your car won't get its proper registration and such but will you be fined or anything for improper pollution?
Old Aug 19, 2003 | 04:16 PM
Sillent Killer
Just don't put in Headers and Test Pipes and you should be fine. If you do choose to put in test pipes because of the big hp gains then it will only take you about 30 minutes to swap the cats back in before the test.
Old Aug 19, 2003 | 06:34 PM
KONVERTER's Avatar
KONVERTER
Originally posted by myinfinitig20
****ing california
im seriulsy thinking of moving to miami florida again...
no emisions testing / rules at all...
**** a mufler
Old Aug 19, 2003 | 06:45 PM
keeptrying's Avatar
keeptrying
How about superchargers in CA? Will they pass the visual?
Old Aug 19, 2003 | 08:24 PM
Strom's Avatar
Strom
Ok, when I said "states like Colorado and California", I was giving examples. Don't take my word on what is checked in your state - look on your state's Department of Motor Vehicles website. In Texas, I have not seen a vehicle visually inspected during emissions testing or seen a tailpipe sniffer used. All I have seen is OBDII tests in Texas.
In California, if something beside a cat-back exhaust is on your car, and you don't have a CARB EO number for it, then you most likely will not pass visual inspection. If something is REALLY out of sight, you may pass if it doesn't affect the sniffer test.
You will not pass with a Supercharger unless it is CARB certified (and has an EO - Executive Order - number).
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
