Rattling noise
Old Dec 8, 2008 | 07:37 AM
Subninja's Avatar
Subninja
Default Rattling noise
So lately I have been hearing this jingling sound coming from underneath the car when I take off in first. It sounds like a metal piece that is only barely loose but it just bugs me because it is new. Any help would be appreciated.
Old Dec 8, 2008 | 07:53 AM
bswanny's Avatar
bswanny
throwing this out because it just happened to me but my muffler tip moved to touching my rear bumper outlet and made a similer sound. Probablly no help but just throwin it out there.
Old Dec 8, 2008 | 09:37 AM
j.arnaldo's Avatar
j.arnaldo
According to CR, the "Body Integrity" department isn't one the strongest points on our beaZts. The power window thingy, the hatch door struts & the gas latch release issue seem to plague our monZters. That kinda overlaps with electrical issues, too. Other than
that, I LOVE MY ZED (flawless engine, flawless AT, flawless cooling system, etc.)
Old Jan 6, 2009 | 11:03 PM
phacket1's Avatar
phacket1
could also be the heat plate or gaurd
Old Jan 11, 2009 | 06:41 PM
lowtempo's Avatar
lowtempo
the best bet is to jack the car up and look at your exhaust. give it a good shake. if it hits anything while you are shaking it then you know where you'll have to do some ajustment. there are some undercarage covers there too, where you might find rocks or pieces of dropped tools, that might be trapped there.
I had a bad rattle that would occur when I excelerated and was driving me crazy. I though my exhast might be the problem, but when I looked under< i saw that the "parking break wire" which runs through the crank shaft housing was somehow unseated and was rubbing against the driveshaft. Im finally gald I found it, as I coudnt stand driving the car with the anoying rattle..... it drives you crazy .....
Old Jan 14, 2009 | 09:12 AM
Subninja's Avatar
Subninja
I think it may be the throw out bearing on my clutch. Anyone know how much to fix that or can you just tighten it (not really familiar with clutch install.)
Obadabot
Jun 18, 2023 11:31 PM
wanderingstuden
Jan 28, 2016 07:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
samansharif
Sep 25, 2015 12:31 PM
