Fresh build
Old Dec 10, 2008 | 11:48 PM
tecni's Avatar
tecni
Default Fresh build
New build:
Arias 9:1 Extreme Duty pistons.
Pauter rods
Cosworth Main Bearings
Cosworth Rod Bearings
HKS Head Gaskets
JWT spring and shim kit
ARP L19 Head Studs
ARP Main Studs
Nissan Revup oil pump
AAM Oil pan spacer
Greddy twin turbo kit (freshly rebuilt turbos) / upgraded oil feed lines.
Greddy spark plugs
SVRT atmospheric dump kit
Carbonetic Triple Carbon Clutch
Steel Braided Clutch line
Three built motors in this pic. Mine in the front, Charley's (my350z member), and 'ol grandpa VH45 in the back.
Washing the anti corrosion coating off the bearings.
HIT A SNAG!
I began plastigauging from cylinder 6 all the way to the front, once I got to cylinder #2, I see this and see I have a scored bearing Now I gotta see if the machine shop can smooth this out for me or if I have to scrap the crank.
Old Dec 11, 2008 | 04:52 AM
Vq.turbo.DremZ's Avatar
Vq.turbo.DremZ
What ever happened to the VH swap? Last time i checked you were trying to sell it...
Old Dec 12, 2008 | 05:24 AM
tecni's Avatar
tecni
Eh... I've had tons of people interested in it. Most of them are just pipe dreamers, others are contemplating a VH/VK swap and just wanna pump me for information and the ones that were genuinely interested in the motor were typically not going to use it on a G35 and then expected a huge discount because they didn't need motor mounts or transmission and failed to realize that I was practically giving those things away. If I don't get what I'm asking for it, I'd rather stare at it in my garage. ...gives me a boner every time.
Old Dec 12, 2008 | 05:28 AM
tecni's Avatar
tecni
Had to perform surgery on the crank.
I took a dremel buffing bit and some compound and buffed out the scratch.
Old Dec 12, 2008 | 09:19 PM
Chef-J's Avatar
Chef-J
Booooosstt!!
Good luck!
Old Dec 14, 2008 | 01:40 AM
tecni's Avatar
tecni
Motor fired right up. No fluid leaks but I do have a small vacuum leak coming from the plenum. I'll be replacing the gasket since its kinda beat up.
Old May 11, 2009 | 06:35 PM
tecni's Avatar
tecni
Update: 12,000 mi on the motor. 500+whp daily driven.
Old May 11, 2009 | 08:26 PM
boostintt's Avatar
boostintt
nice!!!! TECNI built FTW
apex locator
Jul 23, 2021 02:27 AM
350Z_Al
Oct 29, 2020 07:44 PM
