Running engine to 5500 RPM
Old Aug 24, 2003 | 09:59 PM
icekube's Avatar
icekube
Default Running engine to 5500 RPM
Does it harm the longitivity of the engine if you run the engine to 5500 RPM with nearly 4000 KM on the car?
Old Aug 24, 2003 | 11:14 PM
zuff's Avatar
zuff
No!
UNless you intend on keeping it there for an hour straight! But then it's an issue of heat not engine age.
Old Aug 25, 2003 | 01:32 AM
apsilon's Avatar
apsilon
You're well past the break in period. Go test that rev limiter.
Old Aug 25, 2003 | 05:43 AM
Audito350Z's Avatar
Audito350Z
5500... that's nothing! At the track I am always between 4000 and 6500 rpms. I've hit the rev limiter so many times I have a nose-print on the steering wheel where the jolt makes me lurch forward
PeteH
Old Aug 25, 2003 | 09:48 AM
icekube's Avatar
icekube
Great!, So that'll mean I'll be able to drive it harder next time without being scared of doing harm to anything internally.
Old Aug 25, 2003 | 10:49 AM
Chebosto's Avatar
Chebosto
just dont keep hitting the rev limiter. thats bad for the engine.
running all day at 5500 should be fine. it will be fine at even at 7100.
the engine's limit is something like 15 minutes of sustained rpm of 7500+
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Fixxxercask
Nov 9, 2015 11:10 AM
