manual is whining
Old Jan 17, 2009 | 04:30 PM
fireztx's Avatar
fireztx
Default manual is whining
when I am driving in the cold weather between 2k and 4k rpm's it whines.. It sounds like a high pitch whine.. anyone else with this problem?
Old Jan 17, 2009 | 05:58 PM
ODEHBOY's Avatar
ODEHBOY
yes. i had the same problem... take it to the dealer. brand new transmission on the house. thats if u have warranty
Old Jan 17, 2009 | 05:59 PM
Hraesvelg's Avatar
Hraesvelg
Got Uranium?
Yeah I did, then I slapped it around a bit and made it feel bad about itself.
It's quiet now. Same thing works with women.
Old Jan 17, 2009 | 07:05 PM
fireztx's Avatar
fireztx
yeah, i already got one tranny a while back,, It is over 5 years old now so my extended warranty is out...
Old Jan 18, 2009 | 09:11 PM
kevincat's Avatar
kevincat
my car right now screeches real loud when i go faster than 30 miles an hour. i think its the transmission too. hope we can get an answer
Old Jan 20, 2009 | 09:32 PM
ladyzed's Avatar
ladyzed
OMFG
Are you serious? It whined on me when it was -20C (-4F) and it whined but it seemed like the whine came from the rear end.
I have warranty until June so I should get it checked.
Old Jan 20, 2009 | 11:07 PM
Chebosto's Avatar
Chebosto
could it be.. that your tranny fluid is COLD? does it go away when its warm?
Old Jan 21, 2009 | 07:53 AM
350z006's Avatar
350z006
I have something similar going on to what Cheston is saying...when I've had my car parked in the cold for a long time, when I start up is whines and screeches at about 2.5~3K rpm...then goes away when it warms up...
Is this normal...?
Old Jan 21, 2009 | 08:17 AM
Z_ology's Avatar
Z_ology
Cars are kind of like people in that when they are freezing they don't tend to work perfectly. Some noises are to be expected in extreme cold.
Old Jan 21, 2009 | 08:48 AM
350z006's Avatar
350z006
Yeah, I agree...but I'm talking about southern california 60 degrees cold...I'm not sure sure how cold it gets in OP Houston...
Old Jan 21, 2009 | 08:52 AM
mclovin.too's Avatar
mclovin.too
its normal
Old Jan 21, 2009 | 09:13 AM
Z_ology's Avatar
Z_ology
I see...I tought you meant like 0 degrees like it is here now! 60 would be a different story.
Old Jan 21, 2009 | 12:38 PM
terrasmak's Avatar
3rd and 4th seem to do this all the time, mine does this , and has always done this. The 09 (i believe) tranny is worse than the original tranny.
Old Jan 21, 2009 | 05:02 PM
Sixth_Vang's Avatar
Sixth_Vang
In hondas, it's usually the differential fluid. Swap out the differential fluid and see if it makes a difference.
Old Jan 22, 2009 | 05:37 AM
cheshirecat79's Avatar
cheshirecat79
Mine is doing the same thing in sixth gear around 3k rpm. It's loud as hell and only happens when throttle is being applied. If I let off the gas it stops. It's definitely the tranny and not the differential (although the differential was loud also until I changed the fluid recently).
I'll be flushing out the tranny fluid and will let you know if it makes a difference. Now that I got rid of the potenzas and put dynamat in the rear it's the loudest thing on the road at 85mph.
Old Jan 22, 2009 | 01:33 PM
Bevo's Avatar
Bevo
It happened to me in the cold morning too, but it's gone once it's warmed up.
Old Feb 11, 2009 | 04:55 PM
maxuz's Avatar
maxuz
those with this problem, check in here (confirm symptoms on post 18):
https://my350z.com/forum/vq35hr/4142...when-cold.html
Old Feb 11, 2009 | 05:01 PM
Nexx's Avatar
Nexx
Is this normal...?
i get the same thing. its annoying but it goes away after a few minutes of driving.
Old Feb 14, 2009 | 06:02 AM
exZilaration's Avatar
exZilaration
I had the same problem, turns out i needed a new tranny.
Luckily I had warranty, after the swap I still heard a whining around 2ks (give or take) and I live in Florida so the cold isnt bad.
Its normal to have a little whine but if its really loud you should definitly take it to the stealership
Old Feb 16, 2009 | 06:45 AM
maxuz's Avatar
maxuz
stealerships don't know anything about this. They just keep replacing trannies but it doesn't fix it. We need to figure this one out on our own so we can start going to the dealers knowing what we're talking about.
