Injector Installation Help
Old Jan 21, 2009 | 11:20 AM
  #41
minus500's Avatar
minus500
Originally Posted by rcdash
You sold a product that by your own admission shouldn't require spacers. You are offering to fix an item that shouldn't have needed fixing.
WHY WON'T YOU REFUND THE MONEY FOR THE INJECTORS NOW THAT YOU KNOW THAT THEY WILL REQUIRE FIXING TO MAKE IT FIT STOCK RAILS?
You claimed it would work with stock rails. They were sold on that basis. Even with spacers, they WILL NOT WORK WITH STOCK RAILS. They require machining.
I can understand your position - you sold these with pics and the buyer accepted. I can understand you don't want the headache of trying to sell them again. Honestly if you had just said you didn't know if they'd work with the stock rails, and the buyer accepted that, then it would be on them. But that's not the case.
You've got to fulfill your claim - these will work with the stock rail. If you're willing to pay all machining costs and for the spacers, then that might be something, but even there, the buyer shouldn't have to put up with that headache because something you claimed during the sale turned out to be false.
Honestly out of all the guys posted thus far, your the only person who has made some sense. I'm also not offering to "fix" anything. Fixing something implies that it's broken and these are not. These have 0 miles on them and were as good as new. They worked fine in my rails which are identical to the stock rails. Further my rails now have OEM injectors in them and work fine. I didn't have the spacers nor did I say they were included in the sale. I knew they need clips and if you look at my FS thread then you'll see that I had two sets available at an additional cost. My post was clear as was the pic posted and the extra pic I sent her/him via PM. I offered to buy the spacers and send them out of good will even though it was clear that this was an injectors only sale.
Old Jan 21, 2009 | 11:29 AM
  #42
XKR's Avatar
XKR
We are not here to make sense...we are here to collect funds that was paid for a false ad.
Hear me when I say...wont be able to sell a tooth pick.
Old Jan 21, 2009 | 11:57 AM
  #43
rcdash's Avatar
rcdash
grrr....
Old Jan 21, 2009 | 12:10 PM
  #44
SlideFox's Avatar
SlideFox
(observing from the sidelines)
Old Jan 21, 2009 | 12:13 PM
  #45
rcdash's Avatar
rcdash
Come on now, if projektz puts forth a good faith effort, I think minus500 will come around. Post up pics of these injectors with the stock rails - let's see if we can't figure this out before we e-nail someone to the e-cross.
I can't tell who's bs'ing who, if indeed someone is. Clue us in!
Old Jan 21, 2009 | 12:37 PM
  #46
projektZ's Avatar
projektZ
I have talked to a few shops and they say these injectors need to be machined to fit. He told me these would fit with no modification needed. If you do a google search (wish I would have done beforehand instead of trusting the seller) These are used in EVO's STi's and other nissan engines. Not 350Z.. In Minus's 1st post he said he would call altered and talk to them about it but he did not. I called them and they said these injectors need to be machined to fit.
AND ONCE AGAIN THE CLIPS ARE NOT THE ISSUE.
Old Jan 21, 2009 | 12:41 PM
  #47
minus500's Avatar
minus500
^^^At least somebody is decent and is logical. I didn't rip anyone off. I think that there is some inexperience....possibly. As noted, these were run on my built VQ and I now run factory injectors in the very same rails which I will definitely snap pics of today and post cause this is turning into a pathetic witch hunt. I already admitted based on my own research that they need spacers which I offered to send own my dime. That wasn't intentional and it wasn't like I was advertising spacers, clips, etc in the ad. Not exactly anway...I did have clips but I clearly marked in the ad that they were extra.
  #48
rcdash's Avatar
rcdash
Ok, that would be enough work on the part of the buyer. I guess I'm too trusting and thought maybe we pulled the trigger a little too quickly. Guess not.
REFUND IS DUE ANYWAY YOU LOOK AT IT NOW EVEN IF THESE WORKED FOR YOU MINUS. IT MAY NOT BE YOUR FAULT AT ALL - JUST PART OF SELLING. I now hand over this thread to XKR for sentencing...
Old Jan 21, 2009 | 12:45 PM
  #49
minus500's Avatar
minus500
I understand that it's not an issue at this point but one of the first things I heard from Nathan was, "the factory connectors don't work... what the heck." Seriously, NO OFFENSE when I say this but If either of you knew what you were doing in the first place then you would have gotten the clips and not been so stunned when the factory harness didn't work.
Old Jan 21, 2009 | 12:47 PM
  #50
rcdash's Avatar
rcdash
MINUS500, the machining requirement is the issue at this point. No getting around that. Sharif even posted to that effect. Unless you can refute that? It is possible that your rails will accept both stock and these injectors - but the stock rails will not. It's all a matter of tolerances.
You cannot possibly expect the buyer to machine this. Refund.
Old Jan 21, 2009 | 01:16 PM
  #51
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
+1
How many shops have to get on here to support Sharif's and projektZ's statements that these injectors require machining to properly fit the stock fuel rails before minus500 stops this ridiculous BULLCRAP?!?!?!
Quit being a defiant weasel and REFUND THE LADY!!!
Old Jan 21, 2009 | 01:25 PM
  #52
minus500's Avatar
minus500
If it were the rails that would be one thing but it's not and again I didn't rip anyone off. How could these injectors and stock injectors fit in my rails and these won't go into OEM rails? If the stock injectors fit in my rails then wouldn't it be obvious that it would be vice versa 6 of this and half a dozen of the other?
Old Jan 21, 2009 | 01:33 PM
  #53
rcdash's Avatar
rcdash
If your rails are machined differently, then it is entirely possible for them to accept a wider range of injectors than stock. This is getting ridiculous. You have not tested them in stock rails. You cannot assume they will work based on the fact that stock injectors fit in your rails. That is not a foolproof test.
I am beginning to think you bought these in error, AAM told you they wouldn't work, and now you off loaded them onto someone else. I can think of no other reason for the run around here.
Old Jan 21, 2009 | 01:44 PM
  #54
minus500's Avatar
minus500
I am beginning to think you bought these, AAM told you they wouldn't work, and now you off loaded them onto someone else. I can think of no other reason for the run around here.
Not even close. The shop bought them and installed them on my motor and we planned on using a Greddy EU for tuning(This was several years ago almost before the Fcon and The EU was still somewhat popular). I took my car to AAM for an FCon and tune instead of using the Greddy EU that was available. At that time and after talking things over with the owner, it was decided that the power I was looking for could not be accomplished on a 660cc injector so I went ahead and bought a set of HKS 1000cc on Mike's recommendation.
And no, I don't have "magic" rails.
Old Jan 21, 2009 | 01:50 PM
  #55
rcdash's Avatar
rcdash
projektZ, you are officially screwed. Hate to see it. Always buy with a credit card, even on paypal. AMEX refunds no questions asked.
Old Jan 21, 2009 | 01:52 PM
  #56
projektZ's Avatar
projektZ
Yea I am switching over my paypal asap. the only reason I had it up to checking was so I could be a verified buyer and be more trusting to the sellers. Guess I really need to protect myself 1st in this world.
I hope no one else gets scammed.
Big thanks to everyone for trying to get this guy to do the right thing. I appreciate all the support.
Old Jan 21, 2009 | 01:57 PM
  #57
projektZ's Avatar
projektZ
https://my350z.com/forum/itrader.php?u=62779
Old Jan 21, 2009 | 02:04 PM
  #58
rcdash's Avatar
rcdash
The FI guys already put notices in all his other FS threads. The title of this thread should be changed to "MINUS500 is a SCAMMER" and it should go over into the FI section if the mods allow it.
Old Jan 21, 2009 | 02:10 PM
  #59
RudeG_v2.0's Avatar
RudeG_v2.0
でたらめ検出器
Good for you! I bet Ernie wishes he could change his positive iTrader rating that he initially gave minus500.
  #60
projektZ's Avatar
projektZ
I agree.
