flywheel, camshaft, racing piston and spring valve
Old Sep 1, 2003 | 08:07 PM
GY-Z's Avatar
GY-Z
Default flywheel, camshaft, racing piston and spring valve
anybody has any brand that can recomand?
Old Sep 1, 2003 | 09:34 PM
CluelessZ's Avatar
CluelessZ
Default SGP racing
Go here: (sgp racing)
SGP racing website
They carry Tomei Cams, Have their own set of 11.5:1 and 8.5:1 Forged Pistons, Pauter Rods...
New springs, SS valves, Titanium Valve retainers, Bronze Valve Guides.
Etc, etc, etc. They can rebuild your entire engine for a FI setup.
Old Sep 1, 2003 | 11:20 PM
GY-Z's Avatar
GY-Z
Default cluelessz
thanx for helping out..
do u or anybody know watz the gain in hp for nismo's camshaft and flywheel?
Old Sep 3, 2003 | 05:49 AM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
Default Re: cluelessz
Nissan say's the Nismo Cams will add 14hp to the rear wheels with no ECU programming. We have found we have to bump the idle 100rpm with the consult unit or the car feels like it wants to stall when stopping. Also if you have the gas available we bump the timing a couple degrees as well. No matter what cams you buy, don't forget to get a whole bunch of gaskets for your installer..... just so happens we have them (and the Nismo cams) if you need them.
Old Sep 3, 2003 | 12:45 PM
eskimo's Avatar
eskimo
What kind of power increase do these 11.5:1 pistons have?
Old Sep 3, 2003 | 01:00 PM
CluelessZ's Avatar
CluelessZ
eskimo,
You should either call the guys at SGP racing, or start a new thread. Make sure you title the thread "Question for SGP racing regarding the 11.5:1 pistons".
They have a couple guys from their company who are regular posters on this site, and i'm told are very helpful in responding to all questions.
thanks
Old Sep 3, 2003 | 01:54 PM
Nathan's Avatar
Nathan
Check out www.mines-wave.com With 262deg cams, 11.5 cr & exhaust they say 320ps at flywheel
Old Sep 3, 2003 | 05:40 PM
GY-Z's Avatar
GY-Z
wat u mean by "bump the idle 100rpm with the consult unit "?
Old Sep 3, 2003 | 06:56 PM
Chebosto's Avatar
Chebosto
COnsult is the diagnostic tool that nissan dealers use... they can change the idle rpm and to some extent, timing
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
