Weird transmission noise..
Old Feb 5, 2009 | 12:53 PM
plumpzz's Avatar
plumpzz
Default Weird transmission noise..
So when I start my car up in the AM and it's still cold I hear a noise upon depressing the clutch pedal. It sounds like a loud cement-mixer / grinding sound and i can feel it in the shift stick and in the clutch pedal. When I let the clutch go, the noise goes away. The noise also goes away once the car warms up.
Has anyone ever had this problem?
I have a CD009 transmission with about 40k miles on it. I replaced the stock fluid with synthetic fluid of the right rating and type. I used royal purple..
Old Feb 5, 2009 | 12:56 PM
tranceformer95's Avatar
tranceformer95
Well from what you said with the clutch pedal, I'd guess that it's the throw out bearing on the clutch.
Old Feb 5, 2009 | 12:59 PM
plumpzz's Avatar
plumpzz
Sup ray,
But would I feel it in the shifter too? Its vibrating a little and makes unusual sounds.
Old Feb 5, 2009 | 01:41 PM
freedonutss's Avatar
freedonutss
I too have this noise. When I first start up the car with the clutch fully pushed in it doesnt make the noise but once I let the clutch out while im in neutral it makes a constant grinding noise under my car until the clutch is pushed back in. Im not sure if its normal or not I havent heard of many members with this problem. Also if you take your car to the dealer for warranty work on your transmission make sure you have the correct transmission fluid in your car or they will refuse to fix your car because it had the wrong fluid.
Old Feb 5, 2009 | 02:21 PM
GenPac's Avatar
GenPac
I have this issue also, mostly when vehicle is cold. I was leaning towards a failing pilot bearing/bushing.
Old Feb 5, 2009 | 02:28 PM
plumpzz's Avatar
plumpzz
Would that be covered under warranty if the correct fluid is in there? Or is it a wear and tear item?
Old Feb 5, 2009 | 04:47 PM
freedonutss
Like tranceformer95 said I think its the throwout bearing. This is not a wear and tear item and they should replace it. About the fluid you might want to get some more insight on that. I saw a few threads about people putting in the wrong transmission fluid and nissan denying the warranty work.
Old Feb 5, 2009 | 05:09 PM
davidmcc's Avatar
davidmcc
Originally Posted by plumpzz
...I hear a noise upon depressing the clutch pedal. It sounds like a loud cement-mixer / grinding sound and i can feel it in the shift stick and in the clutch pedal. When I let the clutch go, the noise goes away...
+1 on throwout bearing, and yes, you could potentially feel that in the shifter if the vibrations traveled back through the transmission.
...When I first start up the car with the clutch fully pushed in it doesnt make the noise but once I let the clutch out while im in neutral it makes a constant grinding noise under my car until the clutch is pushed back in...
Do you have a lightweight flywheel installed by chance?
Old Feb 5, 2009 | 05:14 PM
freedonutss
No stock flywheel and clutch. I also noticed my flywheel chatters alot when driving in low rpms.
Old Feb 5, 2009 | 06:09 PM
staticfive05's Avatar
staticfive05
i also have the problem when the clutch is pushed in, its normal and clean engine sound, but when in neutral and foot not on the clutch its like a grinder sound but light and i can feel it too. i tell the dealer everytime and they say its normal.
Old Feb 6, 2009 | 04:44 AM
halfass872's Avatar
halfass872
Clutch in----Throwout bearing
Clutch out---Flywheel. Tis is the "normal" noise the dealer is talking about, and yes it is normal.
Sounds like you have a bad throwout bearing.
Old Feb 6, 2009 | 06:09 AM
plumpzz's Avatar
plumpzz
Cool. More money to spend!
Old Feb 6, 2009 | 06:30 AM
djamps's Avatar
djamps
Yup I can confirm "clutch out" noise is normal -- does it on my G and I also noticed it on my friends Z. Even worse when I got a lightweight flywheel.
Old Feb 6, 2009 | 07:27 AM
saint365's Avatar
saint365
I do have same noise when it is cold weather. Should I go to dealer to get it fixed?
Old Feb 6, 2009 | 12:34 PM
AznKaos15's Avatar
AznKaos15
clutch out noise is normal.
it's on my 08 as well.
i've asked someone with a new 07 at the time, same thing.
Old Feb 13, 2009 | 10:57 AM
saint365's Avatar
saint365
so clutch out noise griding noise is normal, but how's other's shift feels? It does not make rattle noice but shift is vibrating alot. I can see it's vibrating. is this normal?
Old Feb 16, 2009 | 08:20 AM
JAbraham03's Avatar
JAbraham03
I just bought a used 2004 Nimo 350Z and I have the same issue with the transmittion. The shifter does move around and vibrated when in neutral. Also when it is in gear you can feel it move when you push on the gas and let off. Also hard to get it into 2nd gear. Any one have any ideas? I am hoping that the dealer I got it from will have an answer along with possibly fixing whatever it is without costing me anything.
Old Feb 17, 2009 | 10:45 AM
CamiloA98's Avatar
CamiloA98
Yes I agree. I have an 06 Base and I too have this noise. I took it back to CarMax and the guy told me that it was normal for 350z. Although it still bothers me when I hear it.
Old Feb 23, 2009 | 11:47 AM
CamiloA98's Avatar
CamiloA98
I have the same problem with 2nd gear and the noise. If you find you what it is please let me know.
Old Mar 6, 2009 | 05:56 AM
jkcz's Avatar
jkcz
Default Cold Tranny noise..
It sounds like I am having the same issue. I have an 06 Base with 18k miles and when its cold it is hard to shift from 1st to 2nd and when the clutch is depressed it makes a weird noise. It goes away as soon as the car warms up.
I'm going to the dealer tomorrow to get my tire sensors replaced(thats another story), but should I tell them I think its the Throw out bearing, or let them try to figure it out? Is the throwout bearing covered under warranty? Could it be anything else?
