head gasket similarites ???
Old Feb 5, 2009 | 10:55 PM
stealthz's Avatar
stealthz
Default head gasket similarites ???
Ok not a usual question but could some one cross reference nissan inventory...? I'm curious if the vq35de head gasket has the same bolt patteren and ports as the vq35hr or the vq37...? And or which head gasket are interchangble with what vq motors... Because if the headgaskets match there's some frankenstine possiblities... That I'm curious about
Old Feb 6, 2009 | 08:03 AM
track1z's Avatar
track1z
Theres alot more then just heads fitting on other blocks.This isn't Ford /Chevy Honda/Acura crap Silly rabbbit.
Old Feb 6, 2009 | 09:10 AM
stealthz's Avatar
stealthz
sensors and brackets I can tap or fab or plug close... so pretty much I just need to know if the heads or decks have the same patterens and same size... plus it's cost productive to have simaliarties... why is the vq motor been used in so many models of nissan? you really think nissan is better than every other company that cuts cost by not haveing interchangable or similar parts?
Old Feb 6, 2009 | 09:24 AM
stealthz's Avatar
stealthz
I'm guessing the head gasket are different but I'm curious to the simalarites like if the bolt pattern and the combustion chambers are the same the only differecnce is just an extra oil port or something along those lines, stuff like that....
Old Feb 7, 2009 | 08:33 AM
1cockyZ's Avatar
1cockyZ
hr head gaskets and bolts work on a de. its a tech article on jwt. I used the hr gaskets and bolts on my de build.
Old Feb 7, 2009 | 04:17 PM
stealthz's Avatar
stealthz
thank you
Old Feb 8, 2009 | 07:10 AM
QuadCam's Avatar
QuadCam
as cocky said......they work. the HR gaskets redirect coolant flow than the DE......a good thing, I beleive.
the bigger issue is to look at how the timign cover mates up to the heads. I don't have any HR heads to compare to. I assume you are thinking of trying to use HR heads on a DE.
Old Feb 8, 2009 | 08:47 AM
stealthz's Avatar
stealthz
vice versa DE heads on a HR bottom... is what I'm wanting to try lol and I"m really wanting to get that 3.7 liter with DE heads... I know I"ll need a new hood and everything... I just need to know if the 3.7 is the same bore with a longer stroke than the 3.5.... the timing cover could become an issue and your right I still need to find out the similarities of those as well... but I figured if they didn't work I would be able cut the HR timing cover in half right at the heads and than weld on the de top to it....
but HR heads on a DE doesn't sound half bad either.... seems like a lil more work, the wiring and the ecu on top of everything else
Old Feb 9, 2009 | 07:29 AM
GreenGoblin's Avatar
GreenGoblin
I will stay tuned for that one.
Old Feb 9, 2009 | 08:57 AM
stealthz's Avatar
stealthz
Yea I'm looking for an hr short block now but having no luck... They're going to be hard to find... But once I get my hands on one it's good to go LOL I already have a spare de...
Old Feb 11, 2009 | 05:21 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
VQ37HR has both increased bore and stroke vs the DE
Old Feb 11, 2009 | 08:42 AM
stealthz's Avatar
stealthz
do you know what the increased bore is?
Old Feb 11, 2009 | 08:49 AM
Z1 Performance
Former Sponsor
sorry just stroke increased, not bore - anyway, you can google all this stuff too
VQ35DE (including revup) - 95.5 mm bore, 81.4 mm stroke
VQ35HR - 95.5 mm bore, 81.4 mm stroke (dec height is taller than DE..IIRC it's about 6mm, don't quote me)
VQ37HR - 95.5mm bore x 86.0mm stroke
Old Feb 11, 2009 | 08:56 AM
stealthz's Avatar
stealthz
well thanks for the google lol I did try and couldn't get that info anywhere.... but cool thanks thats all I needed to know....
Pleask
Dec 21, 2021 03:17 PM
burglapfd
Dec 6, 2020 01:04 PM
sales@czp
Sep 23, 2019 03:30 PM
