Idling and Rev issue
Old Feb 13, 2009 | 06:16 PM
Steven622's Avatar
Steven622
Default Idling and Rev issue
So I've done a bit of thinking, and I can't figure out why my car is doing this.
Here are the symptoms:
When idling with or without heating/AC the rev's will periodically drop quite a bit, like its choking almost, and sometimes will die
When holding the gas pedal at a specific point without load (ie not in gear) it will randomly drop 250rpm or more in the same choking fashion
-- Additional note: This is only if I hold it below 2000rpm, above 2k it does not have this issue
When holding the gas pedal at a specific point with load it will cause hard jerking, and of course act like its choking.
When doing a cold start it sounds like its misfiring when I rev it, goes away after a minute. I don't mean revving it all to hell, I mean going up to 2500rpm
Car itself
K&N Intake, think Popcharger without a heat sheild
53k miles Enthusiast
Stuff I've done:
Changed Oil - Castrol 5w30 synthetic
Changed Diff fluid - Mobil 1 75w90 synthetic (helped a bit with the jerking obviously)
Checked Air filter - its clean
Always used 91 octane gas
It throws no codes, and I have no idea what the issue might be. My next thing I was thinking of doing was changing spark plugs.
Any ideas guys?
Old Feb 13, 2009 | 07:47 PM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
MAF either not connected properly or has gone bad.
Old Feb 13, 2009 | 08:11 PM
Steven622's Avatar
Steven622
Haven't checked that, but wouldn't it throw a code?
Old Feb 13, 2009 | 09:20 PM
TreeFiddyZee
Do WHAAAAT!?
Not necessarily. If it's just starting to go bad, it might not throw a code. If it is going bad, it will get worse.
I had a car with a bad MAF and when I would try to accelerate, the engine would "stall", then take off like a bat out of you-know-where.
Old Feb 14, 2009 | 08:53 AM
Steven622's Avatar
Steven622
Only at low RPMs do I have an issue, never above 2000
Old Feb 19, 2009 | 07:51 AM
Steven622's Avatar
Steven622
Just as an update, I reset the ECU, and so on.
I found that this only happens when I have my heater/AC on.
Surprisingly my voltage dosen't drop below 14, should I upgrade my grounds and hot wire to the alternator?
liqalu04
Jan 2, 2022 12:58 PM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
