Brand New Z, MT 2nd gear issue?
Old Feb 18, 2009 | 05:54 AM
procrit's Avatar
procrit
Default Brand New Z, MT 2nd gear issue?
I just brought home a 2008 350z with 48 miles on the clock this weekend. After driving it for the last 3 days, I have noticed that 2nd gear goes in kind of clunky compared to the rest. No grinding or anything, but it doesn't just slide into gear smoothly like the rest.
Typical of a Z?
Old Feb 18, 2009 | 06:05 AM
procrit's Avatar
procrit
nevermind. found a bunch of posts with the same issue. I still haven't driven it over 7 miles 1 direction, so I probably haven't gotten it warm enough yet. =)
Old Feb 18, 2009 | 06:13 AM
Alberto's Avatar
Alberto
Cranky FI Owner
I run Royal Purple tranny fluid. Ive run it in every MT car Ive had, and it always feels a little smoother with it in. Easy and cheap to do, and it cant hurt if you wanns try.
Old Feb 18, 2009 | 07:40 AM
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
I haven't owned a stick that isn't "clunky" going into 2nd. It's pretty much the nature of physics. If you're grinding, that's one thing, but just being clunky is another. How high are your revs generally when you shift?
Old Feb 18, 2009 | 05:58 PM
Pat Bateman's Avatar
Pat Bateman
My 08 has the exact same issue. It's kinda annoying.
Old Feb 18, 2009 | 06:59 PM
kramykram's Avatar
kramykram
my 08 does it also, but so did my 04 and 03
Old Feb 18, 2009 | 07:41 PM
singh's Avatar
singh
_______________
i wouldn't touch royal purple with a ten ft pole..
Old Feb 19, 2009 | 04:03 PM
JAbraham03's Avatar
JAbraham03
My 04 does it an it always makes me feel that people will think I am just not shifting right....dont like it.
Old Feb 19, 2009 | 07:58 PM
SchismX's Avatar
SchismX
Low rpm shifts typically clunk more. Shifting at a higher rpm will reduce it some. Also using different fluid helps.
Old Feb 20, 2009 | 08:32 AM
Brandon26pdx's Avatar
Brandon26pdx
Typical of a Z?
It must be. I picked up an 08 6spd a couple weeks ago that has ~400 miles on it now (56 when I picked it up), and it does the exact same thing.
Sometimes it will slide into 2nd smoothly, and sometimes the shifter will report back a noticable "chirp" as it slides past the syncro. I've found if you hold onto 1st a little longer it often shifts smoother, and of course make sure you're fully disengaging the clutch.
Possibly the right gearbox oil could help the issue, but in my experience crappier shifting action is just kind of a hallmark of Japanese econo-sportster transmissions. The one in my old MR2 sucked, so did the one in my AWD DSM.
Old Feb 21, 2009 | 12:08 PM
j.arnaldo's Avatar
j.arnaldo
'O4 Touring Coupe: FLAWLESS AT! NO feathering! NO oil-consumption issues! NO PROBLEMO!!!
Old Feb 21, 2009 | 01:34 PM
Pat Bateman
I found one huge problem there.
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
