Anyone Else Using Eneos Synthetic Gear Oil?
Old Mar 6, 2009 | 11:24 AM
ZPirate's Avatar
ZPirate
Default Anyone Else Using Eneos Synthetic Gear Oil?
I recently changed my transmission and differential oil to Eneos snythetic. I got it from a local tune shop. Apparently it's No. 1 in Japan, but only recently became available in the U.S.
Old Mar 6, 2009 | 11:31 AM
UpRev's Avatar
UpRev
Eneos is Nippon Oil, so yes it's #1 in Japan, not because it is the highest quality but because it's in every service station (think back to Initial D). Also why import oil when you have your own reserves. Castrol/ Mobil1/ Valvoline/ Penzoil would cost a fortune over there because the only refineries there are Japanese companies, so they'd have to ship it all over.
Eneos is good oil, I've sold tons of it to various customers since they started selling it here when I worked for another shop. I wouldn't say it is exceptional, it's just a good consumer grade oil. But remember the opposite is true, it's more expensive here because they make it in Japan and have to ship it here. They don't process it here in the States.
Old Mar 6, 2009 | 12:10 PM
ZPirate's Avatar
ZPirate
Thanks for the background on Eneos oil. The tune shop made it sound like it was the best synthetic gear oil for Japanese cars. I was originally planning on using Amsoil.
Old Mar 6, 2009 | 03:07 PM
UpRev's Avatar
UpRev
It's not bad, for consumer oils it's actually fairly good. Amsoil is a bit too much hype for my tastes, good oil, but the way they market it just seems a bit much.
You probably will never have an issue with the Eneos, just consider the price associated with it next time you do a gear oil change. For what you probably paid you could step into a redline, torco, motul, etc
Old Mar 6, 2009 | 03:20 PM
Mike Wazowski's Avatar
Mike Wazowski
I don't know about the gear and diff oils, but their engine oils have not fared very well from the Used Oil Analysis's that have been done.
Eneos was the only oil that ever burned off in my Z. I had to replace 1.5 quarts in less than 3K miles and the UOA were horrible. (check out the oil sticky).
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
Stevo Z
Oct 3, 2015 09:14 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
