Question about swapping pumpkins
Old Mar 11, 2009 | 01:52 PM
Logans06/350z's Avatar
Logans06/350z
Default Question about swapping pumpkins
Found a 06 Grand Touring pumpkin with lsd out of a wrecked car and I wanna buy it to put in my base z. Not sure if its out of a manual or auto. so i wuz wondering if the gear ratios are the same. Or does it matter?
Old Mar 11, 2009 | 02:01 PM
Motormouth's Avatar
Motormouth
auto and MT have different ratios, like a 3.5 for MT and 3.3 for AT.
guys with FI swap into the 3.3 sometimes.
Old Mar 11, 2009 | 02:03 PM
NISMO_558's Avatar
NISMO_558
the gear ratios are different for a manual and automatic transmissions, if its from an auto I believe it's a 3.3, if it's from a manual it should be a 3.5. I could be wrong.
^ beat me to it^
Old Mar 11, 2009 | 04:55 PM
dsmZ's Avatar
dsmZ
i have some perfect condition 3.5's for sale if you want them. pm me
Old Mar 11, 2009 | 05:03 PM
Logans06/350z
Default question
Does nebody know how a 3.3 ratio lsd pumkin performs in a mt z?
Old Mar 11, 2009 | 05:49 PM
dsmZ's Avatar
dsmZ
assuming it will fit, it will rev slower
Old Mar 11, 2009 | 05:57 PM
Gingervitis526's Avatar
Gingervitis526
and you would get better mpg on the highway i would think, lower revs
Old Mar 12, 2009 | 07:42 PM
bbs350z's Avatar
bbs350z
high hp z's swap for the 3.3 for better traction and lengthens the gears a bit.
anything above factory 3.5 is useless if you go f/i, so keep that in mind
Old Mar 13, 2009 | 04:51 AM
QuadCam's Avatar
QuadCam
you are assuming that someone still is in the stock rev range. If you have a 9000 rpm motor, you'll want even more gear than a stock 3.5 final drive.
Old Mar 13, 2009 | 06:09 AM
Motormouth's Avatar
Motormouth
really? you would go even higher? like a 3.9?
Old Mar 14, 2009 | 06:50 PM
bbs350z's Avatar
bbs350z
yes sir i am, and you do have a valid point, but i dont think he has a fully built motor and/or head to make power in the upper rev range.
i am simply stating that if he wants to elongate the gears he'd need a 3.3, which is useless unless your f/i and want to clear up traction issues imo. i assume from your standpoint your talking a high revving motor making power up top as well, and running a shorter gear like the 3.9 or 4.083, which is a way i didnt bother to look at, but is none the less a good alternative depending on the route he chooses to take
issyz
Jul 2, 2017 03:04 PM
Fixxxercask
Drivetrain
Sep 28, 2015 11:15 AM
